restoring underside of sapphire cosworth
Guys what have you been using to restore the underside floor i have been under my floor pan all day cleaning off the waxoyl luckly it does not have any rust yipee!!! mind you it is caked in waxoyl.
i was thinking maybe a white shultz will this give the desired finish or should i shultz then get painted ? any ideas or help thanks
Mine was pretty clean underneath after removing all the engine oil which seemed to have rust proofed it. Seemed a shame to strip it all off, so i just stone chipped the edges around the sills, then coated the whole floor in red oxide, followed by two coats of industrial strength floor paint in grey, which was close to the original colour.
3dr cossie
11
Dec 21, 2015 03:38 PM
3dr cossie
21
Nov 20, 2015 05:00 PM
