grs fitting?
Old Apr 24, 2011 | 11:24 PM
bubs_rsturbo's Avatar
bubs_rsturbo
Default grs fitting?
hi i have just changed my 90 spec front bumper to an 88 spec as i prefer the look, i have still to fit my grs intercooler, will i have to cut the bumper to get it to fit? how hard is it to fit a grs intercooler and is there any othe bits i will need?
cheers Neil
Old Apr 25, 2011 | 11:01 AM
bubs_rsturbo
anyone?
Old Apr 25, 2011 | 11:12 AM
Jimmyc's Avatar
Jimmyc
From what I've heard on 88spec bumpers it depends what fan your using, if standard you might have to get a bit creative and do some trimming, if your running slim fans you should be fine!
Old Apr 25, 2011 | 11:15 AM
bubs_rsturbo
hmmm im running standard fan, maybe worth getting some slim ones then?!
how much are these do u know?
cheers
Neil
Old Apr 25, 2011 | 02:25 PM
Get yourself two slimline fans from airtec,a standard one will give you cooling problems,fitting the grs is simple, you should have 4 lugs on it, drill holes to match on the front panel in the area the fog brackets would bolt on to
Old Apr 25, 2011 | 09:33 PM
bubs_rsturbo
hi mate was looking at it today semms pretty simple.... well it would be if the previous owner of my grs hadnt snapped the 4 lugs off! now im having to find someone to weld new ones on
a quick question should the new fans be mounted to the4 radiator as before or to the front of the intercooler?
cheers
Neil
Old Apr 25, 2011 | 10:03 PM
bubs_rsturbo
also would these do the job? on a budget unfortunatly
http://cgi.ebay.co.uk/2-x-10-SLIM-LI...item2a0e45906d
Old Apr 26, 2011 | 03:16 PM
essexRSTSouthend's Avatar
essexRSTSouthend
If you can,put the fans onto the rad.Its what the fans are designed for other whys you might have cooling problems by mounting them to intercooler.Yes you will need to trim some of the 88spec bumper,as i did to make fit.
Old Apr 26, 2011 | 04:18 PM
bubs_rsturbo
ok mate thanks will the above fans do the trick?
Old Apr 26, 2011 | 04:22 PM
I have mine on the cooler no prob at all with cooling ,as with them fans on ebay you will only know once they are on your car
Old Apr 26, 2011 | 04:25 PM
bubs_rsturbo
ok mate cheers! guess i will give them a go!
ekjim
Aug 27, 2015 05:20 PM
Red_bull
Aug 25, 2015 06:27 PM
Dr. Ickxs
Aug 15, 2015 11:34 AM
RsS2daz
Aug 14, 2015 05:26 AM
track.focus'd
Aug 12, 2015 05:53 PM
