Turbo gasket
Old Apr 23, 2011 | 09:18 PM
russ rs's Avatar
russ rs
Default Turbo gasket
Should you run turbo with or without a gasket between turbo and the manifold
Old Apr 23, 2011 | 09:20 PM
Jimmyc's Avatar
Jimmyc
Without, if your worried about it blowing you need to get the mating faces machines flat.
Old Apr 23, 2011 | 09:32 PM
russ rs's Avatar
russ rs
Ok just seen one in burton power mag and had a bit of panic lol thanks
Old Apr 23, 2011 | 09:35 PM
stevealien's Avatar
stevealien
10 Year Member
mines without,my mates is with
Old Apr 23, 2011 | 09:45 PM
phil_focus's Avatar
phil_focus
as far as i'm aware standard is without.
however, i saw many at central day with gaskets but which is best i dont know.
Old Apr 23, 2011 | 09:58 PM
essexRSTSouthend's Avatar
essexRSTSouthend
Made without gasket but you find its better to use one to make a tight seal.
Old Apr 23, 2011 | 10:03 PM
botters's Avatar
botters
competant bodger
so long as the mating surfaces are flat you will be fine if you use a gasket they tend to end up blowing the gasket anyway
Old Apr 24, 2011 | 07:39 AM
Rogeyboy's Avatar
Rogeyboy
Mines got a gasket, but my manifold was 2nd hand and i never got it re-faced - but you are sposed to use it without, gasket it to take up imperfections!
Old Apr 24, 2011 | 10:41 AM
rstdave's Avatar
rstdave
I tried using the gaskets and always found the material they were made of was poor quality and the centre of the gasket would fall apart causing the manifold to blow.....went back to no gasket and had no more issues
Old Apr 24, 2011 | 10:58 AM
essexRSTSouthend
Guessing you bought a cheap version off ebay.
Old Apr 24, 2011 | 11:04 AM
rstdave's Avatar
rstdave
Me?
Not really, last one i tried was a cometic one so not a cheapy as such.....what's the 'proper' version then, rs turbo's didn't come with one as standard so wasn't aware of a vastly better quality one available?
I know i had the same problems with exhaust manifold gaskets, only the genuine ford ones with the fire ring gaskets ever lasted i found over the years.
Old Apr 24, 2011 | 11:34 AM
essexRSTSouthend
Ford never designed one and only reason i can think was to save costs.There only two versions going about,cosmetic one that looks cheap but spose to be better or the thin metal sleeve.ive only had the metal sleeve version that has flange one side with no problems.
I know what you mean about ford gaskets are best.been down that road..
If you know someone who has the right tools,then get both skimmed for flat surface.studs will get in way tho.
Old Apr 24, 2011 | 04:25 PM
russ rs's Avatar
russ rs
I just run without and see for now seems ok
Old Apr 24, 2011 | 09:01 PM
matthewsimone's Avatar
matthewsimone
Ive recently put a cometec one on mine but thinknig of removing it now after reading a few of these posts! especialy as I keep hearing a bit of a blowing sort of noise when the engine is cold?
RSBryden
Sep 6, 2015 08:39 PM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
cozzzzy power
Sep 4, 2015 08:14 AM
turbowag
Sep 3, 2015 08:07 AM
Jerry Ryan
Sep 2, 2015 08:02 PM
