Performance Cosworth Parts
Thank you for looking
Please note what you see in the pictures is what is forsale, all prices are subject to postage and packing.
RS500 inlet manifold genuine with spacer plate serviced by mountune - £1200
GT30.82 turbo externally gated - £550 SOLD
4 x Green injectors - £110
4 x Black injectors think these are 650cc PN 052F - £110
Quaife MT75 Dog Box Gearbox This also comes with a Gearbox cooler and pump and everything you need to simply bolt the gearbox and pump in for use. A must for any trackday warror
Cheers, Warren
Cheers, Warren
I had the box checked over so I know it's mint inside and would be like fitting a brand new box
For all the PM's on the black injectors I'll post up the part number as soon as I can. What I can say is these are Siemens injectors bought from Ahmed
I'm looking for £500 on the manifold and WG the manifold has been modified to fit the WG so no need to change anything.
Thats the tricky part, I've ran for 3 years on 550bhp and only broke 3rd and 4th gears for the first 2 years then nothing once we sorted out the cooling. When you fit a box like this it makes a 330bhp engine feel like 500+ as the grearing is perfect. This box alone took 3 seconds off my lap round Brands Hatch compaired to standard ratios.
I've said this before but this box transforms the car's perfomance without doubt one of the best mods I've ever done. The gear shifting is so sharp, with no need to use the clutch.
No sloppy gear changes with this selector
3dr cossie
11
Dec 21, 2015 03:38 PM
oilman
Trader Parts for Sale.
Aug 30, 2015 08:37 AM
155lee
Aug 14, 2015 11:21 AM
Aug 14, 2015 07:29 AM
