calling your clutch advice!!!
Old Apr 22, 2011 | 10:29 PM
peteh's Avatar
peteh
Default calling your clutch advice!!!
ok lads, getting my sapph on the road is becoming a nightmare, new steering rack, new front calipers and now it seems I need a new clutch, arhhh!!
note self, never buy a cosworth that's been in storage, maybe low miles but boy are they trouble, lol
Anyhow what sort of clutch do I need, it's running 340ish bhp will a standard be ok or do I need an uprated
Old Apr 22, 2011 | 10:33 PM
peteh's Avatar
peteh
sorry on the iPhone and my chubby fingers hit the wrong button!
want it to drive nice like a standard car, but am worried it'll start slipping then I've wasted my money but then the uprated ones are expensive..
any advice would be good thanks.
Old Apr 22, 2011 | 10:55 PM
hitchwest's Avatar
hitchwest
I have gone standard cover with ap six paddle clutch plate used to spin up on standard before on full boost loads better now and not too heavy on foot my best mate is running a heavy duty alcon and that is quite soft on the foot considering its a heavy duty one a lot of people are converting to the modern hydraulic set up with a centre push kit that reyland sells if any of that makes any sense after a night on the beer
Old Apr 22, 2011 | 11:24 PM
peteh's Avatar
peteh
don't worry mate, I'm in the same boat, hence I can't use this bloody phone! lol
oh right the 6 paddle maybe an option then, take it it's ok to use the original cover?
all I know is with mine it's not releasing, put a new cable on as it was stiff, now can only get a gear if you really bury the pedal sometimes feels the cars still moving ie it isn't releasing.
Old Apr 23, 2011 | 08:28 AM
Papillon's Avatar
Papillon
Wouldnt go for a paddle one on that stage, get an uprated organic. Had one on mine with a slightly uprated cover from sachs which was as easy as the std one and it handled 340bhp easy and comfortable. Paddle discs are for Racing, youll get tired of it driving around town and its harsh on your flywheel and running gear aswell.
Old Apr 23, 2011 | 08:41 AM
Papillon's Avatar
Papillon
Maybe your selfadjusting thing om your cluthpedal worn?
Old Apr 23, 2011 | 08:51 AM
Bloomers's Avatar
Bloomers
Cornish Fasty
i went alcon 6 paddle and hydro conversion, deffo the way forward
Old Apr 23, 2011 | 08:56 AM
If your clutch is dragging with the pedal pressed normally, then space the arm and nipple by means of a nut, with a slit cut in it to allow the cable to pass through so no dismantling, see if this helps.
The paddle clutches are not all for racing that's total garbish, they may well be used in racing but some have perfect road manners, and are actually better/lighter and just as progressive as the std ford clutch.
I would go for a alcon 6 paddle friction plate with a std ford cover/diaphragm, be warned there are two different ford supplied ones, can't remember which is which but one is good one is bad, if money can stretch use a alcon cover as well, AP's tend to be more on/off compared with alcon.
Reyland do a good kit for £350, but it is do able for under £100 using your own bits, and for around £150 you can get a concentric hydraulic clutch conversion, but this is for the chevy T5, so does need some adaptions to fit, just basic machining, it also uses a vastly better hydraulic unit than those fitted to cars as std, ie the std crap has plastic parts whereas the kit mentioned does not, it's fully metal.
Old Apr 23, 2011 | 02:05 PM
Rsmat's Avatar
Rsmat
Ap or Alcon 6 paddle on standard cover is fine for the road IMO
Old Apr 23, 2011 | 05:11 PM
Papillon's Avatar
Papillon
Im just saying a paddle disc is not necessary on that power, ive seen paddle discs ruining both flywheel and cover in a month since the driver didnt know how to drive it, theyre not ment to slip at engagement, think about that when you are launching. There are way better routes to go IMO for road use, especially at that power.. Thats my opinion to this topic, take it or leave it.
Old Apr 24, 2011 | 12:46 PM
peteh's Avatar
peteh
cheers for all the info lads, it's all been great.
next question where do I get a Alcon one from? done a quick search and they seem to be just as expensive as the organic ones!
Old Apr 24, 2011 | 03:03 PM
hitchwest's Avatar
hitchwest
Woodford motorsport mate best by far to deal with will be with you next day if you order before 4pm
Old Apr 25, 2011 | 08:26 AM
peteh's Avatar
peteh
do they just sell them plate by it's self though? all kits I can find at the mo, unless I use teckniclutch, eeeek!!
Old Apr 25, 2011 | 08:02 PM
peteh's Avatar
peteh
any help?
Old Apr 25, 2011 | 08:24 PM
mechanic28's Avatar
mechanic28
6 paddle with heavy duty cover alcon one dont really drive no different from a standard one really
Old Apr 25, 2011 | 08:27 PM
Nash's Avatar
Nash
Cake lover!
They will sell you a plate on its own.
Simon at Woodford pulled me out of the shit a few weeks ago, i was stupid and tried to save some cash by going else where and it back fired. I phoned Simon at 1620 on a Thursday and had my clutch kit with me by 1100 the next morning, amazing service.
IainRS1700T
Sep 25, 2015 06:44 AM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
talon1
Sep 15, 2015 10:27 AM
Flateric_2002
Sep 15, 2015 08:41 AM
