front suspension question?
Old Apr 21, 2011 | 08:53 AM
RsS2daz's Avatar
RsS2daz
Default front suspension question?
hi lads, ive assembled my front konis with new top mount bearings, i compressed the spring and tightened the bearing nut up, everything in the right order, the released the spring but its lose, bearing is as low as it can go, are the springs lose until fitted and the weight of the car settles everything? Cheers daz
Old Apr 21, 2011 | 10:12 AM
Rogeyboy's Avatar
Rogeyboy
I know the rears are def loose with lowered springs, not sure about the front... They must be quite loose as i didn't use a spring compressor to get mine on... Drop the car down on them and roll it back and forth and see how it goes. You can't really get em on wrong providing they are all back together the same as the standard ones!
C2 MAK
Aug 20, 2015 09:46 PM
TrevCos
Aug 17, 2015 09:08 PM
A.t.p
Aug 15, 2015 11:37 AM
dal3door
Aug 13, 2015 06:55 AM
Old ford
Jul 31, 2015 06:50 AM
