Powercord from enginebay to boot?
Old Apr 19, 2011 | 04:30 PM
Tezla82's Avatar
Tezla82
Default Powercord from enginebay to boot?
Hi
I want to get some 30 mm2 from battery to boot for an amplifier
I have this pic:
I've been looking for a hole to use but cant figure out where?
Any suggestions? Drill new hole, but where?
Just need the cable to get in then I'll run it under the carpet in left side and signal cords in right side.
If you could circle the picture to point out where it should be
Thanks!
Best regards
Martin
Denmark
Old Apr 20, 2011 | 09:13 AM
Tezla82's Avatar
Tezla82
Noone knows where the magic hole is?
Old Apr 20, 2011 | 10:33 AM
sionr's Avatar
sionr
unless you have drilled one or removed something you shouldnt have a hole.the loom goes under the fuse box. quickest way is to drill a new one but me personally.id rather listen to me engine
Old Apr 20, 2011 | 10:35 AM
Tezla82's Avatar
Tezla82
Engine IS good music... buuuuut I would like some other music too
Drill new hole you say, but where would be best/smart?
Old Apr 20, 2011 | 10:45 AM
Jimmyc's Avatar
Jimmyc
The thing is your engine bay is the opposite way to ours ie, your batteries on the left not tue right, and your fuse box is the other way, so I'm not sure if all the holes are the same? When I fitted mine i managed to squeeze the wire down the side of the fuse box. if I were to do it again however I would take the wire up through the gromet for the speedo cable through the dash and down Tue interior sill protectors on the drivers side to the boot.
Old Apr 20, 2011 | 01:33 PM
sionr's Avatar
sionr
ye should be plenty of room with the speedo cable or if you wanted to drill it i think to be on the safe side id take the clocks out and atleast you can see both sides of where your drilling.
Old Apr 21, 2011 | 09:11 AM
Tezla82's Avatar
Tezla82
I know about the opposite engine bays
So I'll check the fuse box and see if anything makes sense.
What is "gromet"?
When the cable is in the car, it goes under the carpet in drivers side - and not in the plastic panels as usual.
What about drilling through to the tire - and the into the cabine again? I think I can remember someone mentioned years ago.
Old Apr 21, 2011 | 09:21 AM
Jimmyc's Avatar
Jimmyc
A Gromet is made from rubber, that allows wire to pass through a piece of bodywork whilst keeping an air tight seal to prevent water getting into the cabin or attacking the metal bodywork.
Google it
Old Apr 21, 2011 | 09:35 AM
Tezla82's Avatar
Tezla82
Google it
ooooh yeah... I tried to translate it and it just said gromet again, hehe
I could have searched for gromet at google pics I can see now... Oh well.
Thanks
boeb
Jan 9, 2020 05:11 AM
tankybaby66
Feb 6, 2016 02:24 PM
mk1turboestate
Dec 2, 2015 08:31 PM
chris m1
Sep 7, 2015 08:02 PM
