Ford Range This section is for other models in the Ford range.
cologne pistons
Old Apr 18, 2011 | 08:29 PM
YOREVOL's Avatar
YOREVOL
YOREVOL
Default cologne pistons
engine for sale on ebay, seller states that by fitting 2.9 pistons the compression has been lowered. apparently 2.9 pistons sit 1mm lower.
can anyone confirm this.
Old Apr 28, 2011 | 07:31 PM
If you're referring to a 2.8 cologne being fitted with 2.9 pistons, pretty sure they can't, but not 100%.
Old Apr 28, 2011 | 10:46 PM
pabloXR's Avatar
pabloXR
TA 2008 2009 2012
The 2.9 pistons do fit in the 2.8 block. It's my engine....Everyone said they dont fit but if you look in the haynes manuel you will see that the bores are the same size the difference is in the stroke. The 2.9 pistons have a far deeper bowl that the 2.8 which helped to lower the compression.
I even have a build thread on it for when we bought the 2.9 engine and swapped out the pistons.
Old Apr 28, 2011 | 11:08 PM
pabloXR's Avatar
pabloXR
TA 2008 2009 2012
This is the 2.9 block we bought
2.9 pistons fitted in 2.8 block
Original 2.8 pistons
Old Apr 29, 2011 | 06:16 PM
As I said not 100% sure, the reason for that is I think the best thing to do with any 2.8/2.9 is weigh them in.
Old Apr 30, 2011 | 05:45 PM
pabloXR's Avatar
pabloXR
TA 2008 2009 2012
Uhhh.....can't argue with that, although I found that the blocks make good anchors for ships Oh and the heads weigh 4 stone a pair
Old Sep 12, 2011 | 12:32 AM
MrEngineerdat's Avatar
MrEngineerdat
can the 2.8 pistons be used in the 2.9 for high compression n/a?
or will the valves clash?
Nov 1, 2015 06:53 PM
little bram
Oct 4, 2015 12:13 AM
deathrider666
Sep 28, 2015 06:12 PM
timsrs
22
Sep 24, 2015 08:14 PM
ajamesc
Sep 8, 2015 06:51 PM
