sierra 24v exhaust
would a 2wd exhaust system fit with a 24v boa engine seeing as the original has two seperate downpipes and the 2wd is one pipe for the main system?
from what i can remember no they wont as the granada ones was much wider
you can however fit the xr4x4 downpipes to the 24v manifolds and then use the rest of the cossie system from downpipes onwards as they are the same
from wat i can see the xr4x4 system uses 2 seperate downpipes which then goes into 2 cats which then joins into one pipe.
so presumably i would need this as well as the downpipes then use a 2wd cat back system?
the 4wd sierra pipes run on one side to clear the gearbox but the rest of the system will simply bolt up to the standard cossie system, been there done that
the only issues is that you need 3 bits of exhaust, the 24v manifolds, the 12v downpipes and the cossie system
RB26DETT
Feb 5, 2022 01:54 PM
nico12
Dec 31, 2015 04:42 PM
Adam Graham
Sep 6, 2015 06:04 AM
