Cosworth engine, T5 box, ECU and loom package
Old Apr 13, 2011 | 01:53 PM
mk5tom's Avatar
mk5tom
Default Cosworth engine, T5 box, ECU and loom package
Hi,
It looks like I'm going to have to break my Cortina (in the for sale section).
Heres what I have for sale, ideal for an engine swap/conversion -
Cosworth YB engine, 205 block, on yellow injectors, has had a recent static set up at Motor Sports Developments, new plugs with gaps set, all sensors checked, base CO set, crankshaft sensor gap set (I have the reciepts)
Big wing sump
L6 ECU - not sure if its standard or chipped
Loom and all sensors
Clutch and flywheel
T5 Gearbox - in full working order
T25 turbo - freshly rebuilt by The Turbo Centre at a cost of £388 (again have the receipt)with 360 thrust bearing, done about 300 miles since rebuild, apparently off a Roose Cosworth but can't confirm this.
Basically all the main bits you need to do a conversion. Engine and box have fresh oil (Mobil 1 motorsport in the engine).
The engine is still fitted in car and so can be heard running, it doesn't smoke or burn oil, I'll only remove it once a deposit is paid and then I'll need a couple of days to take it out.
The only thing I haven't had checked/set up is the boost level and fuelling setup so this would need to be done before any hard use.
The following parts are NOT included in the sale-
Starter motor, air filter, intercooler, fuel pump
Collection only, although I could possibly deliver in the North West for the price of fuel.
I'm after £2200 for the lot, its on ebay as well. just pm me with any questions etc.
Cheers Tom
Old Apr 13, 2011 | 07:01 PM
rizla's Avatar
rizla
pm sent
Old Apr 13, 2011 | 11:10 PM
mk5tom's Avatar
mk5tom
Originally Posted by rizla
pm sent
PM Replied to, I'm off all week so you can call anytime during the day.
Old Apr 16, 2011 | 10:29 AM
mk5tom's Avatar
mk5tom
Now sold
big_Rad
Sep 15, 2017 09:36 AM
ekjim
Aug 17, 2015 08:57 PM
RsS2daz
Aug 14, 2015 05:26 AM
gingerturbo
Aug 11, 2015 09:44 PM
wheelwizardrefurbs
Aug 4, 2015 06:23 PM
