Cosworth turbo oil feed supply
Old Apr 11, 2011 | 07:58 PM
mattman1234's Avatar
mattman1234
Default Cosworth turbo oil feed supply
What is the advantage or disadvantage from feeding the turbo directly from the block rather than a 4x4 head ?
Old Apr 12, 2011 | 08:13 PM
From the block area as 2wd the oil is cooler, not having picked up as much heat on it's way through the engine, there is also less potential for foreign bodies, ie carbon deposits to get in the line, as it touches less engine surface, all the crap that collects in the normal running of a engine carbon wise seems to find it's way to the oil galleries in the head, and lodge at the rear of the channels, where on the exhaust side it is further baked into submission from the hot exhaust!!
big_Rad
Sep 15, 2017 09:36 AM
Gaz 88
Ford Focus RS Parts for Sale.
29
May 10, 2017 12:31 PM
Bailes1992
Aug 16, 2015 07:14 PM
muz
Aug 16, 2015 12:57 PM
Aug 14, 2015 07:29 AM
