Cosworth Thermostat Housing problem HELP!!
Old Apr 11, 2011 | 12:08 PM
Cossy Mike's Avatar
Cossy Mike
Default Cosworth Thermostat Housing problem HELP!!
Hello people,
I'm hoping someone can help me, or someone who has had a similar problem,
I've put my thermostat housing in for powder coating and after getting it back it has a pin prick hole in it from corrosion.
So therefore I have managed to source a brand new Genuine Ford item, however it's missing 2 pipe connections on it and I can't for the life of me think of what to do,
any ideas anyone??
thanks
Old Apr 11, 2011 | 01:51 PM
M K's Avatar
M K
The fittings for the pipes on your old one are just push fitted into the thermostat
Housing with some sealant round them so carefully (so you don't crush the
Pipes) clamp some mole grips on each one and twist and pull them out, the use a bit of sealant and push them into your new housing the same way,
Very easy to do mate
Thanks
Marc
Old Apr 11, 2011 | 02:25 PM
Cossy Mike's Avatar
Cossy Mike
Thanks
Marc
Thanks
I've managed to remove the elbow but not the smaller one, it's well stuck in....
Can I not buy new ones somewhere and make it easier?
Old Apr 11, 2011 | 02:29 PM
nugnah's Avatar
nugnah
well seeing as you are not going to use the powdercoated one, cut it to get the pipe out
jas
Old Apr 11, 2011 | 02:38 PM
Cossy Mike's Avatar
Cossy Mike
jas
The smaller one has a pin prick hole in it, so it won't retain water
I'm wondering if I can tap a thread in it and use something.....
I don't want to spoil it with it being a new genuine one
Old Apr 11, 2011 | 02:55 PM
nugnah's Avatar
nugnah
so has the actual housing or the pipe got a pin prick hole ???
jas
Old Apr 11, 2011 | 03:12 PM
James @ M Developments.'s Avatar
can you not tap a thread into the new housing and use a 1/8 npt 6 or 8mm fuel line fitting?
Old Apr 11, 2011 | 04:23 PM
Cossy Mike's Avatar
Cossy Mike
jas
the smallest of the 2 pipes has a hole in
Old Apr 11, 2011 | 04:24 PM
Cossy Mike's Avatar
Cossy Mike
I was thinking of that but I'm unsure of what size and also the bore of the pipe would be smaller reducing the flow
Old Apr 11, 2011 | 05:56 PM
M K's Avatar
M K
Or get flash and aeroquip it like i did
Old Apr 11, 2011 | 07:53 PM
GARETH T's Avatar
GARETH T
if you didnt want to go down the aeroquip route,, you can always just fit hose tails
Old Apr 12, 2011 | 02:10 PM
Cossy Mike's Avatar
Cossy Mike
Now that looks nice
How would weld it up though?
Cossy Mike's Avatar
Cossy Mike
I've been looking mate but I can't find any elbows with a hse tail on
any ideas??
Old Sep 15, 2012 | 07:36 AM
adam151082's Avatar
adam151082
Can i just confirm, to change my thermostat i dont need to remove at the housing like this, i can just remove the 3 bolts and take the smaller bit off at the front. Correct??
Old Sep 15, 2012 | 07:38 AM
adam151082's Avatar
adam151082
Also its 2wd if that makes a difference
Old Sep 15, 2012 | 07:52 AM
Cossy Mike's Avatar
Cossy Mike
Yeah 3 bolts and prise the front off. New seal and stat and pop it back in.
Make sure it's a proper seal though, one that fits to the stat rather than a cheapo o ring
Old Sep 15, 2012 | 09:46 AM
Paul_RS's Avatar
Paul_RS
2WD doesn't have the front piece, but you'll have either 2 or 3 bolts into the head, that's all that holds it on.
Old Sep 21, 2012 | 01:52 PM
ossie cossie's Avatar
ossie cossie
what size are those weld on dash fittings?
Old Sep 21, 2012 | 01:54 PM
ossie cossie
what size dash fittings are these?
Old Nov 12, 2012 | 12:29 PM
booner999's Avatar
booner999
Is this a 2WD 205 thermostat?
Just undo the bolts, pull the lid off? will the water piss out and need fully refilling? or will just a bit come out and can be replaced by topping up the header tank? will this get any air locks in the engine or will it filter all this through?
Then I guess just take out the old, put the new one in, replace the gasket and do back up? fill with water and squeeze the inlet and outlet pipes to the rads with the cap off to bleed the system?
Thanks
Mark
Old Nov 12, 2012 | 12:30 PM
booner999's Avatar
booner999
Is this the one to have as well? What is the difference between the 88 and 82 degree... would the 82 get the car up to temp so the heater works fine? or would I need the 88 in this country?
Old Nov 12, 2012 | 01:07 PM
Cossy Mike's Avatar
Cossy Mike
The stat housing in the picture is 4wd, take the front off swap the stat and replace. You will loose a cup of coolant at most. The elbow has a bleed screw on the top.
I believe the 2wd stat housing is one piece. Take the whole thing off then swap stat and replace.
The 82 and 88 deg stats will open at different times. I personally wouldn't be changing from the stock stat.
If you mean fan switches then that's different
Old Nov 12, 2012 | 01:35 PM
booner999's Avatar
booner999
This is what I have on mine
Is this a 4x4 one?
And is the bolt on top the bleed valve?
Want to be 100% before I go taking bits off
Old Nov 12, 2012 | 02:48 PM
Cossy Mike's Avatar
Cossy Mike
Yes that's 4wd and the top bolt is the bleed screw
Old Nov 12, 2012 | 02:56 PM
booner999's Avatar
booner999
Cheers mate Am I right in changing the thermostat if one of the pipes coming from the rad is cooler than the other?
Old Nov 12, 2012 | 03:35 PM
Cossy Mike's Avatar
Cossy Mike
Radiator top hose and bottom hose will be different temps as its passed through the radiator to cool it. Same as the pipe to and from the heater matrix for your heating.
First thing I would change is the stat
Old Nov 12, 2012 | 04:07 PM
booner999's Avatar
booner999
OK, on that. Will report back when it arrives and fitted.
Just drove it home, another ten miles and fine. To be honest if them hoses are right one being cooler than the other, I dont think there is anything wrong with it, the temp gauage sits nicely, not over heating or under heating, getting hot air from the heater etc... I will take it out and test this one first I think
Old Nov 12, 2012 | 07:58 PM
Paul_RS's Avatar
Paul_RS
If it's working I'd personally leave it well alone - If it's not broken, don't fix it! :P
Old Nov 12, 2012 | 08:07 PM
booner999's Avatar
booner999
See I thought this, how badly wrong can it go changing a stat?
Old Nov 12, 2012 | 08:10 PM
Cossy Mike's Avatar
Cossy Mike
If it's never been changed it'll be rusted to hell. Mine was....worth changing for Ł8
why do you need it changed anyway?
Old Nov 12, 2012 | 08:29 PM
booner999's Avatar
booner999
I just got my doubts about it. It has been changed, engine was rebuilt in 2010 and all this kind of stuff was changed then... I am sure it will still be stiff though... am I likely to break a bolt or something?
Old Nov 12, 2012 | 08:50 PM
Cossy Mike's Avatar
Cossy Mike
Naa bolts will be fine. The problem on mine was because the stat itself is very soft thin metal, it corroded the housing and needed prising out.
It was badly pitted where it sits in the recess so I binned it and bought a new one
Old Nov 12, 2012 | 08:56 PM
booner999's Avatar
booner999
Yeah I am going to replace with a shiney new one At least I know it has been changed recently too
Old Aug 5, 2013 | 09:46 AM
Boubak's Avatar
Boubak
Hi, It's a little bit rude but :
I'm a from france, and I have a donkervoort D8 Cosworth, sorry it's not a Sierra , but the engine in it is a Cosworth YBG, and I have the same thermostat housing.
My problem : The o-ring between this part and the engine block is broken, and
I look at every place possible to find the corresponding o-ring, but I can't find it,
It's very disappointing ><.
Can somebody help me?
If this part isn't anymore manufactured can I just put a flat gasket in place of this damn o-ring?
Thanks a lot in advance for your answers!
Boubak
Old Aug 5, 2013 | 10:18 AM
StephanCosworth's Avatar
StephanCosworth
Boubak
You can buy it here:
http://shop.grahamgoode.com/thermost...17-60994-p.asp
Old Aug 5, 2013 | 10:43 AM
Boubak's Avatar
Boubak
Wow! You're fast, thanks a lot
Old Aug 5, 2013 | 11:59 AM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
I had my rwd housing modded to aero quip and the blanked off out let welded shut
Oct 9, 2015 07:38 PM
CLIVE
Oct 2, 2015 12:58 PM
Aug 14, 2015 07:29 AM
