Radtec 60mm IC... K&N with lobsterback etc, 3dr foglight.
Old Apr 10, 2011 | 06:52 PM
bigluke200's Avatar
bigluke200
Default Radtec 60mm IC... K&N with lobsterback etc, 3dr foglight.
Been having a sort out today: got the following bits for sale
RadTec 60mm IC.. (Not to be confused with the lesser 50mm model - this will be good to 500+bhp)
Fantastic condition.. NO bent fins etc. I gave the front of it a quick coat of black last year for that stealth look. T34 size pipes
These are £360 new from radtec.
Price: £220 as is or £230 for me to key it all up and spray it properly satin black all over. (posted)
T34 turbo hose kit and K&N Group A filter with lobsterback:
filter is the BIG ONE that they do.. It is in good condition but on the underside has the usual pressure marks. (Will not effect filtration and not visible on car) Hoses are in great condition.
Price: £110 posted.
Standard 2wd inlet camshaft great nick, good lobes.
£35 posted.
3dr foglight (N/S I think!) No cracks , great condition.
£20 posted.
Old Apr 10, 2011 | 07:08 PM
bigpower's Avatar
bigpower
you have PM
Old Apr 10, 2011 | 07:18 PM
Cossie_ray's Avatar
Cossie_ray
You also have a PM.
Old Apr 10, 2011 | 07:20 PM
bigluke200's Avatar
bigluke200
PMs replied
Old Apr 10, 2011 | 07:35 PM
bigluke200's Avatar
bigluke200
Inlet sold
Old Apr 10, 2011 | 07:45 PM
bigluke200's Avatar
bigluke200
Heatshield sold
Old Apr 11, 2011 | 10:12 PM
bigluke200's Avatar
bigluke200
Rad Sold
Old Apr 11, 2011 | 10:40 PM
JonnyBravo's Avatar
JonnyBravo
Could I be a complete pita and ask for the measurements of the cooler please, I know its a 60mm core but need to know how much bigger it is with the end tanks etc.. and what the overall height and width is, also the space between the pipe fittings.
Looking to use one on a non cosworth install.
Old Apr 12, 2011 | 06:10 AM
bigluke200's Avatar
bigluke200
I've got some time later this afternoon mate I'll get the dimensions for you.
Wonder what the problem with photobucket is then?
Old Apr 12, 2011 | 09:25 AM
JonnyBravo's Avatar
JonnyBravo
Strange as I've got a advert running on another forum and all my pictures were appearing a few minutes ago.
Would be great if you have time to, thankyou.
Old Apr 12, 2011 | 04:28 PM
bigluke200's Avatar
bigluke200
All sold bits posted today
JonnyB,
Ok mate, got the tapemeasure out.
Widths:
Core:570mm
End tank outer edge to end tank outer edge at top: 700mm front, 715mm back.
as above at bottom:640mm
Between pipes at opening 560mm
Between pipes at Inlet pipe 'kink' 555mm
End of mounting bracket to end of mounting bracket: 860mm
Heights:
Core:400mm
End tanks:415mm
Depths:
Core 60mm
End tanks:70mm
Hope that's of some use mate
Just tried to log on to my PB account and it just says site maintenence hope they sort it!
L.
Old Apr 12, 2011 | 04:30 PM
JonnyBravo's Avatar
JonnyBravo
Blimey ! Thanks very much mate, I'll go and have a measure up now, the only problem I can see is that the end tanks are 70mm as the i/c I have is 80mm and thats far too big to fit between the bumper and the crossmember.
Really appreciate you doing that though
Old Apr 12, 2011 | 05:36 PM
bigluke200's Avatar
bigluke200
No problem mate!
What car are you playing with?
Old Apr 12, 2011 | 05:48 PM
JonnyBravo's Avatar
JonnyBravo
Originally Posted by bigluke200
No problem mate!
Its a Corsa LET I'm doing for a mate, runs a Evo 9 turbo which sadly doesn't leave us with much room to get everything in unless we start cutting the bumper up which we both agreed looks a bit naff.
The plan is to fit the current alloy rad between the 2 intercooler hoses and it should with some luck just about squeeze into the space we have.
Old Apr 12, 2011 | 06:41 PM
JonnyBravo's Avatar
JonnyBravo
Thanks for looking that up, the whole alloy rad were using is 600mm wide, I'm still convinced this is the way to go with things so I'm going to look at using a slightly smaller rad.
Old Apr 12, 2011 | 08:34 PM
bigluke200's Avatar
bigluke200
That sounds insane mate love it!
Good luck in getting it sorted!
Old Apr 13, 2011 | 05:09 PM
bigpower's Avatar
bigpower
Luke
You have PM
Old Apr 15, 2011 | 09:30 AM
bigluke200's Avatar
bigluke200
Prices reduced and sold bits deleted
Old Apr 15, 2011 | 09:37 AM
bigluke200's Avatar
bigluke200
Here's what happens when you trust RM with your valuable parcels
I spend about half an hour packing this thing up for Karl, box within a box, bubblewrap, polystyrene beads etc 'Fragile' Tape all over it and they STILL managed to fuck it. SICK!
Old Apr 15, 2011 | 11:44 AM
The Youth.'s Avatar
The Youth.
whats the size of the outlet pipes on the cooler please?
steve
Old Apr 15, 2011 | 12:55 PM
bigluke200's Avatar
bigluke200
T34 sized mate. (It may be standard size??) 63mm outer diameter at the end where it's beaded then actual pipe is 61/62mm
Hope that helps
Old Apr 18, 2011 | 11:21 AM
bigluke200's Avatar
bigluke200
open to offers....
Old Apr 18, 2011 | 02:18 PM
cossypaul's Avatar
cossypaul
pm sent
Old Apr 18, 2011 | 03:43 PM
The Youth.'s Avatar
The Youth.
Hope that helps
too small!
would mean me buying more hoses as I have a 70mm cooler outlets at the mo
cheers anyway
steve
Old Apr 18, 2011 | 08:00 PM
bigluke200's Avatar
bigluke200
No probs mate
Lobster back now sold... Hoses & filter still available
Old Apr 26, 2011 | 06:01 PM
bigluke200's Avatar
bigluke200
Cooler now £210 posted...
Lobsterback and filter sold but open to offers on hoses....
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Sierrasideways
Oct 8, 2015 06:37 PM
martynhomer01
Oct 1, 2015 12:05 AM
IainRS1700T
Sep 25, 2015 06:44 AM
timsrs
22
Sep 24, 2015 08:14 PM
