Central Locking help 1999 Focus
Old Apr 9, 2011 | 05:01 AM
hellohello's Avatar
hellohello
Default Central Locking help 1999 Focus
Hi,have signed up for help as i'm stuck trying to cure my CL problems
Symptons are:
CL does not work,drivers lock with key does not work,passenger lock with key works ok.
Unplug CL control unit for an hour and CL works fine,drivers lock key works fine.
Next day symptons start to kick in again.
Take out battery in key fob/clean terminals all works fine again,next day symptons come back.
Tried replacing battery in key fob,same results.
(Alternater/speedo sensor playing up aswell but dont think this will afferct CL?)
Thanks
Old Apr 9, 2011 | 06:58 AM
rammer's Avatar
rammer
morning matey
I have the same problem with the CL on my Mondeo, I was told it is the locking motor that is faulty, I must admit I have not tried disconnecting the system and reconnecting , where will I find this on a Mondeo. I do not posses a manual, hope you have an answer soon all the best
Rammer in France
Old Apr 9, 2011 | 04:29 PM
martysmartie's Avatar
martysmartie
Alternator and speedo as you say should not effect it but if the battery is low because of the former this can cause strange problems such as a "Dial sweep" when ignition is switched on.
Martin
Old Apr 10, 2011 | 05:41 PM
hellohello's Avatar
hellohello
Martin
yes battery warning light comes on now and again,alternaor makes a strange noise on turning ignition so maybe low battery due to alternator is causing CL/speedo problems rather than the speedo sensor
rammer,the CL module id in the drivers footwell on my focus,under yhe dash to the right.just unplug the leads
Old Apr 10, 2011 | 05:59 PM
rammer's Avatar
rammer
Many thanks, I must be getting senile , I remember Martin telling me how to do this now about a year ago, I was thinking of a celeonoid or something, Will try in the morning, wines kicking in now, thanks again
Rammer
Old Apr 10, 2011 | 06:17 PM
Chaz888's Avatar
Chaz888
rammer if you have probs finding the module let me know as I have my ford TIS disk with me tonight and can look it up
Old Apr 10, 2011 | 07:15 PM
rammer's Avatar
rammer
Thank you very much, Had a look and found it, will sort it in the morning, and will let you know , thanks again for the kind offer will keep you informed
regards
Rammer
nico12
Dec 31, 2015 04:42 PM
morg65
Escort MK 5 / MK 6
Sep 23, 2015 08:57 PM
richierich1986
Sep 18, 2015 03:29 PM
Flatlinedan
Sep 18, 2015 12:41 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
