4wd turbo and other bits
Bodger of Blackburn
4wd cossie turbo, £130
manifold availble for £10+post and collins actuator for £33posted (circa £70 new and this had a new spring last year from matt lewis motorsport)
will do all the above for £150
runs and doesn't have much movement in shaft, just the usual from a journal bearing turbo.
no smoke on idle or running that i have noticed either.
was last running on a 1.8zvh in my xr2, hence the modified oil return and actuator bracket and arm to clear radiator much better (as seen in my thread link below sig)
can be posted via courier for £8.40.
also have a diaphragm dumpvalve with kevlar diaphragm fitted, good condition does what it says on the tin £30
cheers
sean
cheers
sean
Matt Baxter
Sep 16, 2015 08:30 PM
lockie
Jul 31, 2015 10:03 PM
