Various Cosworth Bits...
4x4 Speedo cable, has some damage to the protection, but works fine - £30
Pillar pod for one 52mm gauge. Its broken away from the actual pillar, so a bit of re-jigging and bonding and it will be good again - £30
Defi exhaust temperature sensor wiring harness, which goes between the Defi control unit and the sensor. The connector to the Defi control unit was accidentally pulled off and I haven't done a 100% perfect job putting it back on, but wire still works. I've put black tape on one side to stop them shorting together - £20
The Defi wiring harness is on EBAY:
http://cgi.ebay.co.uk/ws/eBayISAPI.d...#ht_500wt_1156
4x4 Cosworth starter motor (New from Ford's 4 years ago and only covered 5000miles) - £50
Seat belt bars that go at the bottom of belts and bolt to the chassis - £20
4x4 High flow oil pump, bought from Matt Lewis about a year ago and has covered less than 2000 miles. Im going 2wd oil pump and pick up. Will come with the pick up also - £100
If you require more pictures or details please contact me (Steve) via PM or on 07732 872 122.
Adam Graham
Sep 6, 2015 06:04 AM
