Leccy window issue on Mk1.5
Old Mar 31, 2011 | 12:56 PM
Spurtboy's Avatar
Spurtboy
Default Leccy window issue on Mk1.5
Hi all, when I bought my 2003 Sport TDCi last month the passenger side electric window would go down but wouldn't go up using the passenger switch.
Now it won't go down or up via the passenger switch and sometimes it won't budge using the driver-side switch either.
It seemed like it could just be an issue with the passenger side switch contacts or something, but with it occasionally not working using the driver's side button I'm now not so sure and wonder if it's in fact a motor problem.
Anyone got any ideas?
Old Apr 1, 2011 | 07:17 PM
uruk hai's Avatar
uruk hai
If it does this regardless of which switch is used it may point to the motor playing up, when you push the buttons on either side do you hear the motor or relay clicking at all. My driver side motor packed up then a while later it worked again and it went on working and then not untill i got the motor changed.
Good luck !
Old Apr 1, 2011 | 09:43 PM
Spurtboy's Avatar
Spurtboy
Thanks for the reply mate. There doesn't seem to be any noise whatsoever when I press the buttons, and as I say it seems ominous that it has been so variable in the past few weeks.
I'm going to have a dig about behind the door cards this weekend.
chowfornow
14
Jan 5, 2019 09:01 PM
Mark_
14
Jan 16, 2016 05:27 PM
Nov 1, 2015 06:53 PM
SMILER258
Sep 28, 2015 09:04 AM
cossie330
Sep 27, 2015 04:13 PM
