Need you Help! Suspension question
Old Mar 29, 2011 | 05:26 PM
ST170taylor's Avatar
ST170taylor
Default Need you Help! Suspension question
Hi Guys,
I need to replace the springs on the front of my 2004 ST170,main dealer have quoted £76+vat.
Question is do you know where i can get them cheaper, or will a 2007 ST225 or ST 2.5l springs fit onto the ST170?
i dont want to lower the car just want to keep it standard height.
Cheers!
Old Mar 29, 2011 | 05:37 PM
phil_focus's Avatar
phil_focus
even if the newer st springs do fit it will ruin the handling and more than likely raise the front end as the st is heavier. to be honest i'd just get the ford springs to be sure of the quality.
only other place to try if you want to is a local motor factors. eurocarparts.com deliver if that helps.
Old Mar 29, 2011 | 08:00 PM
ST170taylor
to be honest i was thinking that the newer ST would be heavier and therefore have a higher spring rate, was worth a go though as there are a few sets on ebay for under £20! shame i cant find st170 ones anywhere!
thanks for thr reply though.
Old Mar 29, 2011 | 08:13 PM
phil_focus's Avatar
phil_focus
the only other good option to consider is a full set of eibach springs as they aren't expensive, will firm up the handling withou compromising on ride quality and will only lower the car a little bit. 10 or 20mm.
worth considering imho.
Old Mar 30, 2011 | 01:07 PM
Sp3no's Avatar
Sp3no
I have a complete set of ST170 springs sitting in my garage front and back
Old Mar 31, 2011 | 07:27 AM
ST170taylor
Hi SP3no,
Please see PM's.
Thanks
Old Mar 31, 2011 | 07:48 PM
Sp3no's Avatar
Sp3no
Its easier for me to post the pictures here, just popped out and grabbed these out the garage.
Old Jul 25, 2011 | 11:24 AM
EuroCarParts's Avatar
EuroCarParts
Originally Posted by ST170taylor
Hi Guys,
Cheers!
Hi buddy
Front springs £50 each and if you are a Passion Ford member you get 25% discount!
http://www.eurocarparts.com/ecp/c/Fo...794f92e4f&COIS
Nov 1, 2015 06:53 PM
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
SMILER258
Sep 28, 2015 09:04 AM
