Focus 1.6 2001 issue (fuel related) urgent help please.
Old Mar 28, 2011 | 07:10 PM
L33 BYT's Avatar
L33 BYT
Default Focus 1.6 2001 issue (fuel related) urgent help please.
The mrs has a 1.6 petrol focus on a 51 plate.
it has developed a problem and I could do with some assistance with finding the fault before I start changing loads of bits.
I can start by saying its definatly a fuel issue for two reasons,
A) if I pull the fuel quick release pipes off from the fuel rail I get a dribble of fuel
B) when I flick the key to 2 when the red lights come on I can say it isnt going to start as I dont hear the fuel pump pressurise.
Its definatly intermittant because it only seems to do it after a run, come back to it and the car wont start for 30 mins to an hour.
The fuse is ok, however as a side note it did pop 3 times last year and then never had an issue again.
Fuel shut off is ok (Physical appearance)
Wiring loom does appear to be ok
I have tonight changed the fuel fitler, I have done this as I put a new one on about a month ago as the car had a service, it was a non ford item so tonight put a ford filter on it.
The fuel pump looks a bit of a crappy job,
Does any one think its the fuel pump,
How much will a new one cost,
is it worth me checking out any thing else.
Thanks
Lee
Old Mar 28, 2011 | 07:22 PM
as355f1's Avatar
as355f1
i am sure if the crank sensor is failing on these it cuts the fuel pump. but i would pull the fuel pump first and bench test it.
Old Mar 28, 2011 | 07:28 PM
L33 BYT's Avatar
L33 BYT
Would the spark not fail too? I do get a spark from all 4 pots ok.
Old Mar 28, 2011 | 08:22 PM
steve1010's Avatar
steve1010
I had the fuel pump go on mine, and I'm sure I had random issues before it went.
The pump cost about £100, and I paid a garage to fit at another 100 quid. Sadly, the garage didn't actually attach the fuel lines properly, and I developed a major fuel leak.
I fixed this with a mate, by dropping the tank and fixing the lines in properly.
Wasn't too bad a job - lower exhaust, take off part of the heat shield, and drop the tank by releasing the metal straps that hold it. The pump housing just twists off.
EDIT: Also a 1.6 Focus (02 Plate)
Old Mar 29, 2011 | 03:52 PM
RichieST's Avatar
RichieST
I had identical symptoms with my old 1.6 focus when the fuel pump had had it!
salsheikh
Ford Focus ST Parts for Sale
Oct 6, 2019 07:56 PM
martsmotor
Ford Focus Range
Aug 27, 2015 08:08 PM
salsheikh
Ford Focus RS Parts for Sale.
Aug 20, 2015 12:22 PM
Bailes1992
Aug 16, 2015 07:14 PM
