70 sheets of 8x4 External ply and 65+sheets of OSB Sterling board 9mm thick.
all left over from my unit build and garage build but big cockup in ordering so ended up with nearly a pallet left of each.
OSB 2 External Sterling Board 8x4 9mm (New) £7 per sheet (65 sheets)
External Pine Ply Board 9mm 8x4 (New) £8 per sheet (72 Sheets)
I can deliver for let me know the postcode and how many sheets and ill quote you. i might have a delivery in same area so might be able to split delivery costs.
hi mate i am interested in some of your external ply boards and was wondering if you have 20 of them left, if so i can collect unless you have a vehicle coming closer to cardiff, if you could send me a contact number i could ring you on, thanks carl
timsrs
22
Sep 24, 2015 08:14 PM
