Garage / Workshop & Tools Section. Given working on your pride and joy is often one of the reasons cited for owning a Ford, post all your garage and tool collection pictures and questions in here.
What trolley jack do you have?
Old Mar 27, 2011 | 07:16 PM
steves24V's's Avatar
steves24V's
Default What trolley jack do you have?
Hi, I need a new trolley jack as mine is leaking badly, It just for home use but needs to lift a corner of my land rover collection and also smaller cars 106 / micra etc.
I can only find the small halfords in a case type that will not last with my abuse or full size work shop jobbey is there anything out there that will lift a range rover and easy to stick in the boot of my car to take to around for family cars.
Old Mar 27, 2011 | 07:47 PM
bythomson's Avatar
bythomson
http://www.machinemart.co.uk/shop/pr...smission-jacks
this one looks ok, would fit in boot and isnt dear either
http://cgi.ebay.co.uk/3-Ton-Trolley-...item1c187ecc98
this one looks ok to bit dearer though
i.ve got the shitty halfords one for little things and aten tonne long reach number for heavy stuff that i need up high
Old Mar 27, 2011 | 08:15 PM
M K's Avatar
M K
i got this one and one of the alloy racing jacks but the big fucker would only go in a big boot and it weighs 57.5kgs
http://www.machinemart.co.uk/shop/pr...ift-trolley-ja
Old Mar 27, 2011 | 08:16 PM
steves24V's
http://cgi.ebay.co.uk/3-Ton-Trolley-Jack-Premier-Rocket-Lift-Sealey-3003CXQ-/120670047384?pt=UK_Lifting_Moving_Equipment&hash=i tem1c187ecc98
The sealey ones are good jack my mate has one but a bit big and heavy for the boot, otherwise I'd go for that.
Old Mar 28, 2011 | 07:35 PM
LewisT's Avatar
LewisT
Got one of these ok it is big but it is light
http://cgi.ebay.co.uk/Low-Entry-Quic...item3a6349ab98
Old Mar 29, 2011 | 06:12 PM
Daveysaff's Avatar
Daveysaff
Skint Passionford User
Bought this from Costco last night, only £83 with the vat!!
4 full stroke to full lift and 14cm entry height
Better than the old halfords own shite I used to use lol, this actually fits under the car without having to drive onto blocks of wood!
Old Mar 29, 2011 | 07:41 PM
steves24V's
That looks cool ^^^^^ how much can it lift
Old Mar 30, 2011 | 07:01 PM
Daveysaff's Avatar
Daveysaff
2 tonnes or 1.83 tons
Old Mar 30, 2011 | 08:28 PM
gus's Avatar
gus
its bigger than the car your building!
Old Apr 1, 2011 | 04:00 PM
Char1ie's Avatar
Char1ie
The blue alloy racing jacks sold under various brand names are a bit so so. Nice and light, and low so they get under lowered cars, but mine is leaking and goes down slowly - it comes with a seal kit which I need to do but has only lasted 18 months before it's time to do the seals.
Charlie
Old Apr 4, 2011 | 10:45 PM
Shilly's Avatar
Shilly
sealey new yankie 3 ton low entry high lift
Old Apr 4, 2011 | 10:54 PM
studabear's Avatar
studabear
if you want something to lift a range rover how about a bottle jack under the axle if its just to change a wheel? this will fit in your boot
paceo
Sep 25, 2015 08:05 PM
Adam Graham
Sep 6, 2015 06:04 AM
rsturbo27
Sep 5, 2015 05:08 PM
hopper350
Sep 4, 2015 12:53 AM
