What to Expect from my first Cossie
Well, I have had the saff for 8 months now and its been driven about 2 miles
I took it off the road immediately last year to restore the underside and strip and rebuilt the engine. By the time i had finished, it was snowing
So, im booked in for my MOT next Wednesday and it will be the first time i have had the opportunity to drive the thing. I have at the minute a bit of a weird spec, as the car was originally a stage 3 setup, but was stripped of various parts before I bought it. So, its basically standard other than a T34.43 with a Forge Actuator, panel filter and a mongoose exhaust. I have rebuilt the bottom end and new valve stem seals etc.
I have bought a custom chip from MSD for stage 1 but with the T34. I have to run the thing in, and being my first 2wd cossie, I didnt want to go mad.
So, has anyone ever ran a Stage 1 setup with T34 as im hoping it wont drive like a pig. Im expecting it to be a little laggy ??
. So, im booked in for my MOT next Wednesday and it will be the first time i have had the opportunity to drive the thing. I have at the minute a bit of a weird spec, as the car was originally a stage 3 setup, but was stripped of various parts before I bought it. So, its basically standard other than a T34.43 with a Forge Actuator, panel filter and a mongoose exhaust. I have rebuilt the bottom end and new valve stem seals etc.
First thing to expect is bills the second will be driving along making sure everyone is being quiet as you can hear a bad noise and cant work out what it is lol
Welcome to Cossie Ownership
lol
Personally I would have gone for stage 3 provided you have a decent HG, at the moment you are getting no gain with the T34, it's only used to provide boost the the T3, I would upgrade the injectors and MAP sensor and maybe if you asked MSD kindly they would rewrite your calibration?
T34 isn't exactly laggy, it would be slightly more so than the T3, it dosen't matter what stage it's at to run it is, it's how it's driven which will run it in. I stayed off boost when running mine in and gave it little bursts every now and then.
Martin
Martin
What to Expect from my first Cossie,
Big repair bills,
Spending big money on modifications,
Spending big money in general on it,
But its worth it cos they are great fun!!
Big repair bills,
How come, I bought a custom map from you when your website was updated earlier in the year for this specific reason, i was running a non standard setup. I gave my full car spec, and MSD did the chip to suite apparently. ??? This is what I was told. Is this not the case then??
How come, I bought a custom map from you when your website was updated earlier in the year for this specific reason, i was running a non standard setup. I gave my full car spec, and MSD did the chip to suite apparently. ??? This is what I was told. Is this not the case then??tabetha
Stu/james/msd will have supplied a map/chip that matches what you told them, I think James may have misunderstood your comment when you say a stage 1 that's all, using the chip number you could always phone to check, but if you said T34 that's what they will have supplied, just a misunderstanding on James's part I expect.
will it drive any differently than a Stage 1 with a T3...... I have driven my mates with stage 1 setup on the standard T3 but im assuming with the T34, it will come on boost differently.
Fun times and bad times. Love mine to bits but i have spent a fortune on it in the 7 weeks i have owned it, latest thing is the new engine loom i have just ordered.
But when its right its so right, nothing better than seeing one on the road now i own one its the second best feeling in life.
Not sure how it will drive to be honest. One thing i'm 100% sure of though is that in about 2 weeks you will want more power. Always the case with cossies.
mine was awsome when i first got it drove it all the time had loads of fun in it.. since modding it the worries started and the more i did and spent the more i worry.. now i never use it cos its always waiting on parts .. the worst thing i did was have it painted as i dont like leaving it anywhere.. wish i left mine as a nice stage 3..
It will have slightly more lag than a T3, but depending on the chip will come in harder, do you know what psi it is written to run ?
It will give the turbo a easier time and last longer than a T3 running the same boost, and have more potential for later mods.
I run a T3-34.48, a T3 compressor housing machined out to take a T34 inducer, with std .48 turbine, on a RST rear section, my boost starts at 1400rpm, full boost by 2500rpm, but I have modded the inlet ports around the ends where the valve closes.
The very first thing you want to do is to get a fuelling check done as well as the fan and pump rewire for peace of mind, and engine life.
They can be totally reliable do good mpg and give good service if looked after, they are amazing for the age of the car.
I will be taking it down to MSD for a full checkover in a month or two, so hopefully it will be spot on. Cheers for all the advice
mines running in at the moment on a t34 .63 and around 12psi of boost, its actually quite quick without even revving it high lol.
If (or indeed when :P )you do go 'stage 3' forget the old Bosch injectors and use Siemens 55lbs one instead!
Don't go and show it boost untill the duelling is checked under load, the STD injectors will lean very easily on a t34, so you may well have to cap boost lower, best get her on asap for a check over mate, and ideally a set of greens or 55s to suit your t34
Gunship is a cracking conversion imo. If i'm being honest the best drivable road cossie i had was my NMS T34.48 Greys setup, the car made 360bhp/363ft/lb and was an absolute hoot to drive, lag didn't even exist on that car...
Was that on the gunship Pete cos I have a set of grey and wondering about weather Karl would gunshi it
To be honest from whats being said by MSD a T34 isn't best suited to what is otherwise a standard engine so you may as well change the injectors you have etc and ask MSD if they would provide another calibration instead of the one you currently have?
Do you know what HG you have?
Martin
Won't be Gunship as that uses stock components and it certainly won't make that power, I should think the Gunship is around 300HP, I don't like the idea personally.
Martin
Martin
why u going stage1? first day i got my car, i removed the blues and the stage1 chip. added greens and had a stage3 chip put in! as i was informed this is what the car was intended for. needs a set up after the new tps. but love it evary time it comes on boost, 22psi out of my t3
nice
cause im a big girls blouse and im too scared to play with the big boys
nah, i just want to get used to the car and run the engine in first. I may go stage 3 later in the year. Ive forked out close to £4000 this year building the car up from a rolling shell https://passionford.com/forum/pictur...n-3-years.html
Its starting to piss me off already, spent all day getting it running, polished etc and now the fucker is leaking coolant from the thermostat housing
its had a full gasket kit fitted as well, piece of shit. Im gonna take it off and put some gasket sealer on there too.
Its missing as well when cold. When pulling away is splutters and nearly stalls, then revs itself to 2.5k revs briefly then settles back at idle. Idles mint though. doing me head in
its had a full gasket kit fitted as well, piece of shit. Im gonna take it off and put some gasket sealer on there too. Its missing as well when cold. When pulling away is splutters and nearly stalls, then revs itself to 2.5k revs briefly then settles back at idle. Idles mint though. doing me head in
