focus st blackeyes
Old Mar 24, 2011 | 07:25 PM
slack05's Avatar
slack05
Default focus st blackeyes
focus st blackeyes
if i bought a focus st3 without black xenons is there any way to black the chrome part of the headlight for example splitting the lens off
i am just in the process of buying one so want sure if you could do the mod
thanks if anyone can help
Old Mar 24, 2011 | 09:57 PM
sykes2009's Avatar
sykes2009
im not much help mate as i only have a lx focus but i think they can be split using the heat method all though dont quote me as i also dont have the xenons
sorry i no not much help
Old Mar 26, 2011 | 03:10 PM
slack05's Avatar
slack05
cool ill have to have a bash if i get the car thanks for the reply
Old Mar 26, 2011 | 03:16 PM
RichieST's Avatar
RichieST
Yes I've done it!
Also painted the chrome ring around the headlight bulb, makes a big difference. I'll see if i can dig out some better pics.
Old Mar 26, 2011 | 04:40 PM
sykes2009's Avatar
sykes2009
how do you split them rich using the oven is it a hard job i keep thinking about painting mine but standard black one are about Ł35 so i dont know if its worth doing
Old Mar 26, 2011 | 04:41 PM
sykes2009's Avatar
sykes2009
standerd non xenons are Ł35 i mean
Old Mar 26, 2011 | 04:45 PM
RichieST's Avatar
RichieST
I didn't bother with an oven, just carefully prised the glue apart with a small screwdriver, worked slowly until the cover pulled off. I won't say it was an easy job as the screwdriver went through my finger a couple of times, but definately worth it!
Old Mar 26, 2011 | 05:16 PM
sykes2009's Avatar
sykes2009
how did you put them back together with some clear sealent
also what paint have you used
Old Mar 26, 2011 | 05:19 PM
RichieST's Avatar
RichieST
I just used matt black paint from halfords and I used tigerseal to stick them back together with, it's very similar to the glue that ford use in the first place.
Old Mar 26, 2011 | 05:35 PM
sykes2009's Avatar
sykes2009
mine dont want to come apart its just chipping away around the edges
Old Mar 26, 2011 | 05:51 PM
RichieST's Avatar
RichieST
Your being a bit fierce then mate, takes probably a couple of hours to gently prise each one apart!
wowk
Mar 30, 2021 07:49 PM
tankybaby66
Feb 6, 2016 02:24 PM
Sp3no
Sep 27, 2015 07:23 PM
Tank Mike
Sep 26, 2015 08:07 AM
