ABS sensor resistance?
Old Mar 24, 2011 | 02:44 PM
WongRS's Avatar
WongRS
Default ABS sensor resistance?
Again, sorry , i cant find anything with this friggin search function on here!
My ABS lights on, again, just tested the resistance on all sensors, 3 of them are at 1085 and the one other is 1102, is that about right, or is the one reading higher my problem?!
I dont remember the light being on when i parked it there 6 months ago! lol
Old Mar 24, 2011 | 07:44 PM
steventoon's Avatar
steventoon
i would remove them all and give the place where they sit a good clean. i'm not sure what the resistance of them should be.
Old Mar 24, 2011 | 08:37 PM
GVK.'s Avatar
GVK.
Google found this
Wheel Speed Sensor Circuits
1. Ensure ignition switched off
2. Disconnect ECU multi-plug
3. Connect ohmmeter between harness multi-plug terminals listed below:
o LHF: 7 and 25
o RHF: 5 and 23
o LHR: 4 and 22
o RHR: 6 and 24
4. Resistance should be 900 to 1400 ohms
5. If resistance not as specified:
o Disconnect the appropriate wheel sensor from the car loom.
o Measure resistance across wheel sensor at plug on end of sensor.
o If outside above range, replace wheel sensor.
o If OK, check wiring between sensor connection and ECU.
Old Mar 24, 2011 | 08:38 PM
nellyscossy's Avatar
nellyscossy
the resistance changes as the wheel rotates, you cant really check them that accurately the only proper way to test them is with an oscilloscope as said you can check continuity through loom easily and if you get an open circuit directly on sensor then that would be an obvious fault
Old Mar 24, 2011 | 08:44 PM
fraser9764's Avatar
fraser9764
resistances are fine, does the light stay on from start up, or come on when you start driving?
Old Mar 24, 2011 | 09:29 PM
WongRS's Avatar
WongRS
i cant remember now, i cant really start it as its in a few bits, i think it comes on once it moved, ive cleaned everything out today though, so may of cured it!
Old Mar 25, 2011 | 04:24 PM
fraser9764's Avatar
fraser9764
if it comes on when moving its normally a sensor that needs cleaning.
Old Mar 25, 2011 | 04:47 PM
shortymaz92's Avatar
shortymaz92
Is the abs light orange or red
Old Mar 25, 2011 | 05:18 PM
WongRS's Avatar
WongRS
oraqnge
Old Mar 26, 2011 | 04:01 PM
shortymaz92
Originally Posted by WongRS
oraqnge
Have you tried an oscilloscope on it ? also check the wheel speed sensor to to see if thats not come out aswell.
Old Mar 26, 2011 | 06:54 PM
WongRS's Avatar
WongRS
nah, i haven't got a scope or know how to use one!
Old May 17, 2012 | 07:56 PM
Did you ever fix this matey.
Old May 17, 2012 | 08:38 PM
WongRS's Avatar
WongRS
It fixed itself, my abs lights like a fucking disco though, and now id imagine it's going to be on permanently with 2wd stub's in the back of it.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
