Cosworth bottom end and head standard crank and head
Old Mar 21, 2011 | 07:18 PM
siscossie's Avatar
siscossie
3-door moonstone
Default Cosworth bottom end and head standard crank and head
Have a 2wd bottom end 205 block complete with pistons, STANDARD CRANK, conrods, oil pump, sump, water pump and pulley, power steering bracket. The oil cooler and the crank pulley are not in the sale, took a cap off to look at the bearings and they are ford bearings with no marking to say its been ground.
£350 for the crank on its own
£550 for the lot as above
Also have a 2wd head think its standard measured 139.16( but measuring gear not great
Comes with cams, caps,pulleys, £450ono
Drop me a pm or ring on 07855300612 if interested
please no timewaisters
Old Mar 22, 2011 | 01:38 PM
siscossie's Avatar
siscossie
3-door moonstone
Going on ebay in the next few days
Old Mar 22, 2011 | 04:39 PM
siscossie's Avatar
siscossie
3-door moonstone
Some close ups of the head
Took the sump off, taken number 1 and 2 conrod caps off and measured the crank both were 51.93
And took number 2 main cap off and it measured 56.92
Old Mar 23, 2011 | 08:22 PM
siscossie's Avatar
siscossie
3-door moonstone
Now listed on ebay
http://cgi.ebay.co.uk/Cosworth-205-e...item1c1a6e1a0e
Old Mar 23, 2011 | 11:11 PM
AndyPen's Avatar
AndyPen
pm about the head Si, will try and ring - bit late now tho
Old Mar 24, 2011 | 03:28 PM
siscossie's Avatar
siscossie
3-door moonstone
Reply`d fela ring any time
Old Mar 25, 2011 | 01:47 PM
siscossie's Avatar
siscossie
3-door moonstone
Crank now on ebay
http://cgi.ebay.co.uk/Cosworth-crank...item1c1a7902c3
Old Mar 30, 2011 | 07:37 AM
Yura's Avatar
Yura
the crank should be machined to +.25 for future use
Old Mar 30, 2011 | 10:04 AM
siscossie's Avatar
siscossie
3-door moonstone
Looks like it just needs a polish
Old Mar 30, 2011 | 11:50 AM
Yura's Avatar
Yura
suggested diameters should be for STD size journals - main 56.975-56.959, conrod 51.993-51.977. So, 51.93 and 56.92 is not within the range.
manuel boeckx
13
Oct 3, 2015 02:29 PM
IAN RS2k
Aug 18, 2015 07:51 PM
john_3.0s
Aug 15, 2015 07:44 AM
Aug 14, 2015 07:29 AM
