New Disc's
Here are some pictures of my new disc's and my brake cailpers that i had powerd coated
What do you think??
Driver's side
Passenger side
Picture of them behind my wheel's
Brian
What do you think??
Driver's side
Passenger side
Brian
whats the point in dimples in the disks .
holes ok
... The face grooves will slice the brake pad material allowing the pad to bite harder into the disk, therefore causing an increase in disk temperatures
holes ive been told can cause them to crack unless 8mm drill poked through
the holes very often "i had black diamond on my old s2 "
looked
FOOKING PAIN to clean clogged up Eventually
more looks than more braking power
looked
FOOKING PAIN to clean clogged up Eventuallymore looks than more braking power
Steve Escos
Ford Focus ST Parts for Sale
Sep 2, 2019 11:39 PM
SMILER258
Sep 28, 2015 09:04 AM
