Escort Mk3 soft top Rebuild
Old Mar 14, 2011 | 11:48 PM
History's Avatar
History
Default Escort Mk3 soft top Rebuild
Ok, Probably not up to some of the standards i have seen on here, but I'll post a few pics and appreciate any comments.
All Started when i cleared my garage out, found my old cab burried under a pile of Parts, and thought id give her a quick respray and drop a spare engine in i had. As you will see it snowballed....
Old Mar 14, 2011 | 11:55 PM
History's Avatar
History
Started by rebuilding the engine.
Wrong water pump i know, been that long since i did anything like this, i have been having problems remembering what is interchangeable from mk3 to mk4
Old Mar 15, 2011 | 12:03 AM
History's Avatar
History
Then i went to take the other engine out... Not Good.. It had been repaired bodywork wise 12yrs ago, before i bought her as a shell. Well lets just say it was worse than i remembered.
Well to cut a long story short, it ended up like this...
Then..
Looks like it had a rear driver bump, and front passenger bump. Slide hammered out the back dent, (after removing a fist size lump filler)
Old Mar 15, 2011 | 12:12 AM
History's Avatar
History
Managed to get a genuine ford inner wing, (fleabay) but Passenger side wing was a pain to source, and i got charged well for it.
Hadrian Motor panels supplied all the other panels. (although i got them cheaper going through an agent than dealing direct)
Welding was a mix of Mig, Tig and Arc depending what mood / if i had one the lads from work helping.
Old Mar 15, 2011 | 12:24 AM
History's Avatar
History
Then it was time to prime...
Put about 8 litres High build on in the end. wanted all the panels straight, lol
Then i bonded the Kit on
Including a RS1600i front spliter
Then Resealed all the panels
Then in a moment of i borrowed a couple litres of primer from work... and primed it again. (more on this later)
Old Mar 15, 2011 | 12:34 AM
History's Avatar
History
Then into base coat and the lacquer, with a tint.
Not the best conditions
Extraction Cut out, lol
Old Mar 15, 2011 | 01:40 AM
Ginge's Avatar
Ginge
www.virtualseason.net
That looks like great progress so far, going to be keeping an eye on this, love the colour!
Ginge
Old Mar 15, 2011 | 07:49 AM
colarado red's Avatar
colarado red
Nice work.Stunning colour.
Old Mar 15, 2011 | 08:49 AM
History's Avatar
History
Thanks i like colour as well. went through 100's of colour chips, then added the tint.
Unfortunately the primer i borrowed from work turned out to be acrylic.
When we started to polish her up. Big blisters as the paint lifted.
So nothing for it... 8 litre's of paint stripper and alot sanding latter..
Old Mar 15, 2011 | 09:05 AM
History's Avatar
History
After a grueling two weekends...
Painted again.
Not as much pearl this time.. i am tempted to paint again, but due to a looming house move i am running out of time.
Old Mar 15, 2011 | 01:09 PM
History's Avatar
History
Next up putting her back together again...
All new bolts for a start.
Measure up all the old one's
Then Some nice new Bush's
Old Mar 15, 2011 | 01:13 PM
cossie891's Avatar
cossie891
crack on fella
Old Mar 15, 2011 | 01:21 PM
History's Avatar
History
Every Part i have taken off i have tried to replace with a new part. where this is not possible i have had the parts shotblasted and powder coated.
If i had the time i would of had them eco blacked as well. To be honest now i have gone this far i wish i had had the shell shot blasted, Still 5 litres of waxoil have made the underneath presentable, lol
Shocks and springs were new, just sat in the garage for 8 yrs,
30mm drop
New tie bars and some nice Braided Flexy Hose's
Old Mar 15, 2011 | 08:14 PM
nickscunny's Avatar
nickscunny
Looks great mate. Im about to start a rebuild on my mk3 cab i did 3 years ago.....
Old Mar 15, 2011 | 08:52 PM
History's Avatar
History
Sweet, have to post me your link.
Struggling to get some parts personally. have to pick your brain.
Got a Recon Gearbox for it, Forgot they changed the gearbox casting for the engine mounts from mk3 to 4. Having to swap all the parts over.
And i cant find new engine mount bush's anywhere. (Gearbox one's)
Hope i remembered right that Transit one's fit. Find out when they show up.
If not, i'll have to manufacture new Mounts.
Old Mar 16, 2011 | 03:13 PM
History's Avatar
History
Shows how long it's been, (Nearly 10 yrs) since i messed around with cars.
Forgot ford changed The casing on the gearbox...
Mk3
Mk4
Dam Cast alum engine mount broke as well..
Still easy fix luckily. Alum weld it up
Clean it up. Not bothered to put the Hole in, waiting to see what the engine mounts are like. Soon machine one in.
Old Mar 16, 2011 | 03:23 PM
History's Avatar
History
Started getting the Front end ready, replacing all the rubbers, Ball joints, bush's etc.
Most of the stuff was new, although some Items have sat in my garage for a long time, so needed some TLC.
Steering Rack Polly bush's were tricky to fit.
Cheers lads..
Escort love in, lol
Old Mar 16, 2011 | 03:36 PM
studabear's Avatar
studabear
Cool project, well done for saving it, it must have been soul destroying having to strip all the new paint off.
Old Mar 16, 2011 | 04:04 PM
History's Avatar
History
gutted
Just a little, Big respect to a couple friends who helped. (Bates brothers) i just felt like hitting a bottle.
Old Mar 16, 2011 | 04:11 PM
History's Avatar
History
Bumper overrider clips, Rotten through.
Just flattened one out and used it as a template so i could laser a few blanks out. will have a play bending them tomorrow. Made them from St/St now, Lets see them rot this time.
Old Mar 17, 2011 | 06:52 PM
Colin-Tempest's Avatar
Colin-Tempest
Seriously Newbie
Very nice build! You've had a lot of bodywork, bloody hell!
Looks good now, very nice color!!
And go easy on the new parts... dont upset the misses
Old Mar 17, 2011 | 07:00 PM
mattseries2's Avatar
mattseries2
Love that colour!
Old Mar 17, 2011 | 07:16 PM
nickscunny's Avatar
nickscunny
Cant wait till its done...... Makes me wanna get on with my rebuild......
Old Mar 17, 2011 | 07:25 PM
Mr S1's Avatar
Mr S1
Don't ask - I don't know
Nice to see another Mk3 being restored - and properly
Old Mar 17, 2011 | 07:40 PM
Top work mate shame about the dodgey primer lol.Keep up the good work matey.
Old Mar 17, 2011 | 07:50 PM
Steve the Plumber's Avatar
Steve the Plumber
The original Rouge Trader
Looks good and a nice colour too!!
Old Mar 31, 2011 | 09:50 PM
History's Avatar
History
Been awhile.... struggling with small awkward jobs.
worst problem was engine mounts.. could i get any could i *******.
Tried fitting transit mounts, back one was ok, but front one hit the anti roll bar.
Then finally tracked some new mounts down.
Transit one ^^
old and new mounts, plus the transit one ^^
put the front end together aswell.
Beleave it or not that's all been shot blasted and powder coated. ^^
Rebuilt the Front brakes.
rested a few shiny parts on just to get some motivation.
Old Mar 31, 2011 | 09:53 PM
RO13 rs cabriolet's Avatar
RO13 rs cabriolet
Need a white s2 escort
Very good project that mate keep up the hard work
Old Apr 1, 2011 | 07:45 AM
cutch's Avatar
cutch
Series 1 4x4 cossie
looking real good mate, what wheels you going to put on??
Old Apr 1, 2011 | 03:11 PM
Zetecfiesta's Avatar
Zetecfiesta
really good work on this mate, like a good rebuild!
Old Apr 1, 2011 | 10:53 PM
History's Avatar
History
Series one turbo, had them polished a few years ago so they like chrome.
should look nice with the paint.
Trying to keep the car pretty standard, with just subtle change's.
Managed to get the roof back on, ran the new brake pipe's and cleaned / refurb a few parts tonight, finally got on the flypress to bend the new over rider clips as well.
will post some pics tomorrow.
Old Apr 2, 2011 | 07:53 AM
Fordmad!'s Avatar
Fordmad!
Love this thread!
Old Apr 6, 2011 | 11:15 AM
History's Avatar
History
I hate Doing brake pipe's, but someone had replaced them before, made a real mess. don't think there was more than a foot in a straight line.
Finally Folded the Bumper over rider clips. St/St now
Roof on.
Door Handle's, few other bits. etc
Finished the brake pipe's of now, and started remaking the wiring loom.
I'll take some pics latter.
Cheers for the nice comments.
Old Apr 6, 2011 | 09:36 PM
s23rta's Avatar
s23rta
Love it keep it up
Old Apr 11, 2011 | 06:10 PM
xr2imetalhead's Avatar
xr2imetalhead
that well nice mate well done
Old Jun 3, 2011 | 12:07 PM
History's Avatar
History
replaced all the hose's with braided or silicone
Dash in
just messing around tidying up the interior and installing the ice at the minute. picture's need updating so bear with me please. had a few health issue's aswell (mini stroke) so everything is going slow.
nice shiney new lights ^^
Old Jun 3, 2011 | 12:57 PM
tincho84ar's Avatar
tincho84ar
WOW....nice work man...
Old Jun 3, 2011 | 01:19 PM
Looking great ,get well soon
Old Jun 10, 2011 | 05:52 PM
History's Avatar
History
nearly done
Old Aug 8, 2011 | 09:05 PM
History's Avatar
History
Finally Got round to Starting her up to-night, small problem, a friend who has been helping me didn't put the fuel push rod back in. (he's only young, first car with a carb he's ever seen, lol) so question... What length should the push road be. ? so i can manufacture a new one. anyone got an idear.? be a big help.
