major need of help
Old Mar 14, 2011 | 08:50 PM
archy's Avatar
archy
Default major need of help
Hey guys im in major need of help got a 90 mk4 xr3i running efi the problem is ive got a running problem that i just cantr figure out
If i drive sensibly get major hesitation kangarooing and is also running mega rich done the usual service plugs filters etc but yet still no joy in major need of help
Old Mar 15, 2011 | 10:34 AM
Assume you also did fuel filter ?, have you used BOSCH plugs by any chance ?
Old Mar 15, 2011 | 10:42 AM
archy's Avatar
archy
yes changed fuel filter aswell lol and no running ngk plugs as always had best results with them
Old Mar 18, 2011 | 08:58 PM
archy's Avatar
archy
Default seems to be cured ..............
Hey guys disconnected each injector in turn then the tps now seems to run without lurching/kangarooing so happy happy thinking was sticky injector etc just gotto get the mixture setup then im sorted
Old Mar 19, 2011 | 12:11 AM
AstoN_B's Avatar
AstoN_B
An eye for detail...
i had this problem, or at least similar. two injectors were knackered and two were borderline.
although im led to believe they run a tad lean anyway the EFI's so richening slightly can smooth them out.
AstoN_B's Avatar
AstoN_B
i had fuel pressure reg tweaked slightly too to help injectors out.
Old Apr 3, 2011 | 08:22 PM
archy's Avatar
archy
hey guys sorted the kangarooing but still running mega rich the kangarooing was throttle position sensor
3i Jim
Nov 20, 2015 05:12 AM
IainRS1700T
Sep 25, 2015 06:44 AM
hopper350
Sep 4, 2015 12:53 AM
track.focus'd
Aug 12, 2015 05:53 PM
