gt3071r 0.82
Mar 13, 2011 | 05:56 PM
gt3071r 0.82
GT3071R 0.82 only covered around 2k miles made 470HP on liams old cortina £700
gary
07949030615
Mar 13, 2011 | 08:33 PM
Mar 13, 2011 | 08:46 PM
Is this internaly gated Gary.
Steve
Mar 13, 2011 | 08:53 PM
Mar 13, 2011 | 08:55 PM
Mar 14, 2011 | 06:37 AM
Mar 14, 2011 | 11:07 PM
Was this an import job or proper uk supplied version mate?
Is it this spec-
TURBINE
Wheel 60mm W/84 trim
Housing .82 ar
COMPRESSOR
Wheel 71mm. W/56 trim
Housing .50 ar
4" inlet
Does it have the 2" or 2.5" outlet???
the larger 60mm turbine wheel as found in the gt3076r was an option I read?
Thanks
Marc
Mar 15, 2011 | 02:33 AM
Also any pics of the rear of the turbo, and the v band adaptor
Is their any play in the shaft?
Thanks
Marc
Mar 15, 2011 | 06:21 AM
4" anti surge 2" outlet, i believe it was supplied by ian howells @ area six for liams cortina (ian built the engine)
there is tiny bit of play but no more than is usually associated with a BB Turbo
Mar 15, 2011 | 08:26 AM
What you using on the nova now ?
Mar 15, 2011 | 09:41 AM
Quote:
Originally Posted by
carlo
nova is being broken for spares
Mar 15, 2011 | 09:53 AM
you got another project on the go ?
Mar 15, 2011 | 10:07 AM
carlo
no time to take a time out for a while
Mar 16, 2011 | 06:27 AM
Mar 16, 2011 | 11:58 AM
turbo Prov sold pending payment cheers
Mar 16, 2011 | 02:56 PM
turbo back up for sale
Mar 17, 2011 | 05:51 PM
Just for the record chip supplied me the turbo so he should be able to confirm any detailed specs...
I believe it was the bigger turbine wheel..
Mar 17, 2011 | 06:57 PM
Does the bigger wheel cause more lag than a standard gt3071 or quicker spool up
Mar 18, 2011 | 05:38 AM
CHRA - Garrett GT3071R with full size 60mm turbine wheel and 71mm 56 trim compressor wheel.
Compatible turbo P/N's:
700177-5023s
700177-5022s - this is my turbo
Mar 18, 2011 | 09:47 PM
bump
Mar 20, 2011 | 07:27 PM
Mar 20, 2011 | 08:51 PM
my offer still stands if you want?
Mar 21, 2011 | 06:27 AM
Webby``
thank you for interest but i wont accept it at the price you offered
Mar 24, 2011 | 09:46 AM
Mar 24, 2011 | 11:16 AM
*** Sierra RS Custard ***
turbo1
what do you mean "a standard gt3071", this one is standard.
There are different wheel sizes available as standard from the factory, this is the larger one, which means it will make a little more horsepower and be a little laggier than the smaller one.
Thats how it always tends to work with turbos.
Mar 24, 2011 | 11:19 AM
Yes referring to the bigger exhaust wheel
Mar 24, 2011 | 11:50 AM
bigger wheel = more lag yes
Mar 26, 2011 | 06:37 PM
Pm's replied but please no more Dreamers I will not sell turbo for 400
Mar 26, 2011 | 08:27 PM
Gary do you know anyone with all the bits i would need to get it on my cossie?
Mar 29, 2011 | 06:21 PM
Martin hadland can supply the bits
Mar 29, 2011 | 06:25 PM
Rufly how much do you know bud?
Mar 29, 2011 | 07:05 PM
Apr 15, 2011 | 12:51 PM
Apr 15, 2011 | 01:06 PM
Amazed that took a month to sell, lol
Apr 15, 2011 | 07:48 PM
any one no a other for sale
escort_rst
Jul 10, 2015 07:21 PM
rsdan123
Jan 23, 2013 05:14 PM
coachworz
Feb 1, 2010 11:37 PM
