Fiesta's Other ! This section is for ALL types of Fiesta models that are (NON RS / ST) Such as ZETEC S /S16000 / METAL /TITANIUM / GHIA etc
Help with missfire please Fiesta RS turbo
Old Mar 13, 2011 | 04:44 PM
Adam.'s Avatar
Adam.
Needs Beer Tokens.....
Default Help with missfire please Fiesta RS turbo
Hi guys started my fiesta up for the first time in a year since i have converted to the t3 and fitted beige injectors/ front mount, and i seem to have a slight missfire at low revs but it clears if you rev it abit more, the cars due to go off and be set up soon so im assuming the new injectors might be the reason?, i do have 1 odd lead but it has always been there and never been a problem.....any ideas? cheers
Old Mar 13, 2011 | 04:45 PM
Oranoco's Avatar
Oranoco
I would start with new plugs and leads mate
Old Mar 13, 2011 | 04:51 PM
Adam.'s Avatar
Adam.
Thanks for your reply bud i have ordered some new plugs and leads, the plugs havent had much use but i took the odd one out to check it and it was soot black. which i assume is overfuelling?
Old Mar 13, 2011 | 06:07 PM
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
Presumably you are using the same chip but with bigger injectors until you get it set up. I am assuming beige injectors whatever they are, are bigger than the standard ones? If so, then a rich miss-fire a low revs will be the cause as indicated by soot black plugs.
Old Mar 13, 2011 | 09:17 PM
Adam.'s Avatar
Adam.
cheers mate i have a superchip but not sure if is a 165 or 195, as they both look the same :S
paceo
Feb 3, 2016 10:31 AM
carlo
24
Oct 5, 2015 08:20 PM
s1turboman
Aug 29, 2015 04:27 PM
Ben26
Aug 27, 2015 08:56 PM
paceo
Aug 27, 2015 12:45 PM
