Ahmed track spec springs....
My sapphire is running Konis with track spec ahmed springs. After jacking car up to change wheels the other day, I've found out that the o/s/r spring has snapped. I thought that after jacking it up the spring had popped out after driving it down the road to get a feel of the car on 17's. Got back home and jacked car back up and found that the spring had broken about three qtrs of the way down
after closer inspection off all the springs they appear to be quite rusty, so plan to replace all four springs, any advice on what springs to buy?
after closer inspection off all the springs they appear to be quite rusty, so plan to replace all four springs, any advice on what springs to buy? Last edited by mattygreen; Mar 12, 2011 at 07:36 PM.
Depends on what spec your car is. Ahmed would only let me buy the track spec ones as they are stiffer at the rear. I had mine powder coated and they have been fine for the last 4 years.
SMILER258
Sep 28, 2015 09:04 AM
