spec me a turbo
alright guys can some of you turbo guys spec me a turbo for my zetec build.
i am aiming for around 300Bhp at the wheels but if not at the fly would also do.
engine spec
diamond racing pistons
eagle rods
erst manifold
apr con rod bolts
race bearings for con-rod and crank
so what turbo will be best for me to bolt on to my erst manifold?
cheers for the help
engine spec
eagle rods
erst manifold
apr con rod bolts
cheers for the help
cheers guys only problem i find is the focus manifolds dont seem to come up to often.
budget wise for the turbo is day around £200-300
Leigh are u using standard cams with your build or aftermarket ones ? I'm doing the same build as u and looking for 300+ bhp using a focus Rs e/manifold with a gt2860rs turbo I'm just wondering if I will need cams to achieve that bhp ? Cheers
the standard blacktop cams will do over 400hp.
Ford Focus RS Parts for Sale.
Jun 2, 2016 06:46 PM
Oct 9, 2015 07:38 PM
Matt Baxter
Sep 16, 2015 08:30 PM
