Help needed - Turbo oil feed & filter
Old Mar 12, 2011 | 01:19 AM
BRAMMER's Avatar
BRAMMER
Default Help needed - Turbo oil feed & filter
I want to build an in line filter kit - similar to the picture due to the costs that the tuners are asking for them
The kit will be for a GT30 so AN4 is needed
What i need to know is:
Fittings needed
  • 1x 90 degree (to fit AN4)
  • 1x 90 degree (to fit oil sender .... need to confirm thread size for this)
  • 1x 45 degree
  • 1x straight fitting
Now then.......
  • Where to source the fitting from in the colour like the picture?
In line Filter
  • I have been looking at the Goodridge 149 micron AN4 filter which seems to be the one to use or is it a different size filter for different applications - can this be confirmed?
Many thanks in advance
Chris
Old Mar 12, 2011 | 07:27 AM
www.carbuildersolutions.co.uk
is worth a try, or if no luck try, www.ratsport.co.uk or BGC Motorsport in Wisbech, Cambs
Old Mar 12, 2011 | 07:54 AM
gibbo frst's Avatar
gibbo frst
exact engineering in totnes in devon have all this stuff and all made on site.. shame you are so far away but i think they have a catalogue online..
01803 866464..
this is where a lot of the places get the braided brake kits from like woodford ect..
Old Mar 12, 2011 | 08:01 AM
R4N SS's Avatar
R4N SS
I had a filter like that on my moonstoner and I paid around 70 or 80 quid from RichardPon when he used to work at SCC. Bought it at ford fair years ago
Old Mar 12, 2011 | 08:27 AM
chaffe's Avatar
chaffe
Turbocharging Technician
does the yb oil feed for the turbo come off the un-filtered side of the block?
Old Mar 12, 2011 | 02:14 PM
BRAMMER's Avatar
BRAMMER
Checked the links above and nothing - proper confused as the zinc covered fittings and the size i'm after are for brake and clutch applications - i take it you should be fine using them still for oil hose they should fit ok?
Old Mar 12, 2011 | 05:52 PM
chaffe's Avatar
chaffe
what about the rest of the engine? should there not be filters for that oil?
Old Mar 12, 2011 | 06:47 PM
BRAMMER's Avatar
BRAMMER
Oil comes out of the oil adapter on the inlet side of the block and is returned to the sump on the exhaust side - normally the turbo feed isn't filtered standard these filters are added for extra security
I think i have solved it, i have sourced where to get all the parts to build one, will post up when i get them.
Old Mar 12, 2011 | 06:51 PM
chaffe's Avatar
chaffe
surley the engine oil is generally clean though? and it all passes through the filter at some point, what are you filtering out of the oil?
Old Mar 12, 2011 | 07:02 PM
BRAMMER's Avatar
BRAMMER
The engine has an oil filter - the turbo feed come from a different area to the right of the engine filter (on a 2wd) - the turbo in line filter is a separate item
Old Mar 12, 2011 | 07:07 PM
chaffe's Avatar
chaffe
Manufacturers dont put seperate oil filters on and have no problems, just change the oil and filter often and use a quality oil. The only contamination in the oil will be the engine itself failing, it will be too late then as the turbo will already be dammaged by low oil pressure
Old Mar 12, 2011 | 07:13 PM
The main thing that could cause a blockage is carbon, using a flush from new eliminates this, I always flush, got 200K out my last cossie engine, before oil rings let go.
Old Mar 12, 2011 | 11:06 PM
Moonstone Steve.'s Avatar
Moonstone Steve.
Try these m8, i have used these for all my fittings, he is a m8 of Spiky on here.
http://cgi.ebay.co.uk/6-AN6-06-90-DE...item23078a66e4
Also i have seen on ebay the fitting for the turbo that bolts on if the Gt series has ythis option.
Steve
Old Mar 12, 2011 | 11:11 PM
Moonstone Steve.
http://cgi.ebay.co.uk/Ford-Cosworth-...item3a63c2fd8b
Steve
Gaz 88
Ford Focus RS Parts for Sale.
29
May 10, 2017 12:31 PM
track.focus'd
Aug 12, 2015 05:53 PM
Roosie
Aug 9, 2015 07:37 AM
col93saphcos
Aug 7, 2015 03:21 PM
Escortdriver1
Jul 31, 2015 02:36 PM
