Wiring stereo to parking brake.
Old Mar 11, 2011 | 07:47 PM
barkman's Avatar
barkman
Newbie!
Default Wiring stereo to parking brake.
Hey guys and gals.
I have fitted a w404 alpine stereo to my mondeo 2004 but there is a lead that needs connecting to parking brake to access the options screen.
Where can this be wired to?
i am aware of bypass boxes which i may purchase but in the meantime is there
1) a place to connect it properly (view video only when parked etc..)
2) a work around to watch video, access options at anytime?
Thanks
Old Mar 11, 2011 | 08:28 PM
Blue-Oval-Bass's Avatar
Blue-Oval-Bass
Most parking switches are just an earth , basically when handbrake is applied earth circuit completes and opens the viewing mode.
Just prep the earth surface , ground the wire and you shoud be good to go.
muttlyst's Avatar
muttlyst
simple mate just solder into earth in radio loom job done
Old Mar 11, 2011 | 08:46 PM
barkman's Avatar
barkman
Newbie!
So if connect the parking brake wire to the black earth that will wor?
Old Mar 11, 2011 | 08:53 PM
taz1787's Avatar
taz1787
Escort Cabriolet Owner
yes it will
Old Mar 11, 2011 | 09:01 PM
barkman's Avatar
barkman
Newbie!
Okay thanks I will try this tommorrow. Why do people bother with alpine bypass boxes if it's so simple?
Old Mar 11, 2011 | 09:05 PM
Blue-Oval-Bass
I think the alpine bypass box is really just a expensive way to ensure theres no back emf coming through the earth side of things.
I normally put them direct to ground but tapping into the earth on the loom is fine.
Old Mar 12, 2011 | 06:01 PM
Blue-Oval-Bass
How did you get on ?
Old Mar 12, 2011 | 06:10 PM
barkman's Avatar
barkman
Newbie!
It works thanks. But video does not work? I'm using the USB iPod cable, any idea what lead I need?
Old Mar 12, 2011 | 07:00 PM
Blue-Oval-Bass
Not clued up on the video side of things , pop over to Talk Audio site and ask in there.
will get the details across for you.
Nov 1, 2015 06:53 PM
Adam-M
Was It You?
Oct 1, 2015 07:55 PM
stevecfrst1
Sep 30, 2015 05:18 AM
rsguy
44
Sep 29, 2015 03:29 PM
Carlbacciochi
Sep 26, 2015 04:23 PM
