first mot with st170 engine mtech v4 and bike throttle boddies
ok its time to see how mr mot man likes my mapping!
the st170 setup is fitted with the cat from the old 1.8 engine atm
i run the idle adjuster slightly open and retard the ignition to -5 degrees then below 800 rpm i have 15 degrees ignition advance because there isnt an idle control valve and no ignition based idle control in the software
what i was wondering is does retarded ignition cause changes to the emissions test even tho its mapped to a rock steady 1 lambda/14.7:1?
with the ignition at 10 degrees and the idle screw reduced it's crappy at parking and bogs down when the fans kick in or drag the clutch in a traffic jam
and yes the boddies have been ballenced!
so will the retarded ignition give me problems?
cheers
cheers
if i have the idle screw set at 800rpm and 10 degrees ignition it cant compensate for the fans kicking in because there isnt enough air going in to create torque for the alternator no matter how much ignition i add below 800rpm. its rearly easy to stall when setup like this
i dont have a problem with the 3000rpm test plenty if ignition and sits at 1 lambda niceley
i have to have plenty of air going in then counteract it with some retard (-5 degrees) then the site below 800rpm have lots of advance so it stops the engine going below 800rpm and prevents stalling so it behaves like it has an idle control valve
it works verry well like this but i'm unsure if it will cause a fail on the mot test
i suppose i'l take it as it is and see what happens and leave a bottle of scotch on the seat with the testers name on it
oilman
Trader Parts for Sale.
Aug 30, 2015 08:37 AM
Ben26
Aug 27, 2015 08:56 PM
track.focus'd
Aug 12, 2015 05:53 PM
gordyshreds
20
Aug 10, 2015 02:59 PM
