mondeo st155 tdci engine noise help!!!
Old Mar 9, 2011 | 11:56 AM
richiefirefighter's Avatar
richiefirefighter
Default mondeo st155 tdci engine noise help!!!
hi i just got myself a 56 plate st 155 with 79000 miles on the clock, it seems to have an intermittant hollow noise from the engine only on idle and it doesnt matter if its hot or cold, what could this be?? there is no smoke from the exhaust or any other rattles or noises, has a full service history as its an ex fleet car, help really needed from u guys cheers
Old Mar 14, 2011 | 10:40 AM
Daveyraveygravy's Avatar
Daveyraveygravy
Is it a 'droning' noise?
If it is then it's the bottom pulley. If you do a search on google for it you will find it's a VERY common problem and can only be fixed by changing the bottom pulley, tensioner and the auxilary belt. There are other mondeo forums which have more infomation but im not sure if im allowed to put a link on here to them.
It wont affect the engine if you dont change it, but it may drive you bonkers listening to it rumble away at idle. If you dont want to pay the Ł300-400 to change it, turn the stereo up!!!
Old Mar 15, 2011 | 02:49 PM
richiefirefighter
yeah i had a look at the aux belt while it was idling today and you are 100% right, i can see it vibrating exactly when the noise occurs, having it done under the warranty where i bought it and also the slight clicking as i turn left too which i dont know the cause of
Old Mar 17, 2011 | 09:36 AM
Daveyraveygravy
Not sure of the clicking, but you must insist they change all 3 parts or you will have it come back again.
Fords were replacing these under warranty and even had a TSB about it.
Old Mar 17, 2011 | 10:52 AM
richiefirefighter
hi what exactly are the three parts and what is a TSB ?? cheers
Old Mar 17, 2011 | 04:26 PM
GVK.'s Avatar
GVK.
Belt
pulley
tensioner
Technical Service Bulletin
TSB 18/2005 I think?
http://www.avforums.com/forums/attac...lley_guide.pdf
track.focus'd
Aug 12, 2015 05:53 PM
