s2 rs turbo flywheel
Old Mar 9, 2011 | 10:06 AM
testosterone's Avatar
testosterone
Default s2 rs turbo flywheel
hi, right , my problem is that the ring gear on my flywheel has worn to the point of the starter not engaging the flywheel, so what i would like to know is that , what flywheel could i use as i cant source a rs one. Obvously its 220 mm plate . Also just to say its the 1.9 american turbo block but still thinking the crank is standard .
many thanks
Old Mar 9, 2011 | 01:56 PM
Why not just get new ring gear fitted ?
Old Mar 9, 2011 | 02:36 PM
phil_rs's Avatar
phil_rs
yam yammer
Any 1.6 cvh flywheel will fit (providing it's the same diameter of course)
Old Mar 9, 2011 | 05:00 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
heat it up and knock it off, then replace with another one.
yatta
May 21, 2016 10:31 PM
RSBryden
Sep 6, 2015 08:39 PM
cozzzzy power
Sep 4, 2015 08:14 AM
turbowag
Sep 3, 2015 08:07 AM
Jerry Ryan
Sep 2, 2015 08:02 PM
