2wd diff oil
Mar 8, 2011 | 07:12 PM
2wd diff oil
What do I use ?
Cheers Paul
Mar 8, 2011 | 08:20 PM
i use 75/90 fully synthetic same as in the t5 box.. recomended by marco and bara.. box runs a lot quieter now too..
Mar 8, 2011 | 09:26 PM
Thats what I've got cheers mate
Aug 31, 2011 | 06:38 PM
sorry to bring this up, but what make did you get?
Aug 31, 2011 | 07:28 PM
Also how hard is it to change as I don't have a clue
Aug 31, 2011 | 07:34 PM
just undo the lower bolt, drain, then replace this one and pour into the higher bolt untill it over flows....
and replace bolt or course, lol.
takes 1 litre i believe.
Aug 31, 2011 | 08:10 PM
Is it just the same as gear box then or is there a plate to remove also can I use same oil as gear box
Aug 31, 2011 | 10:17 PM
Quote:
Originally Posted by
peteh
Always make sure you can undo the higher bolt ( fill hole ) first, before you undo the lower bolt ( drain hole )
Sep 5, 2011 | 01:26 AM
Mike1
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
Fezman1
Sep 7, 2015 09:34 PM
cbminis
Sep 7, 2015 09:42 AM
