Best Diagnostic Machine
Old Mar 8, 2011 | 12:49 PM
strawhead_rst's Avatar
strawhead_rst
Default Best Diagnostic Machine
What is the best machine at the minute for a garage working at a range of motors
Dont mind paying for the right machine
Old Mar 8, 2011 | 03:15 PM
DAN P's Avatar
DAN P
I use a 100 one from ebay has never let me down and does all cars with obd 2 from 2000to 2009 so far
Old Mar 8, 2011 | 07:38 PM
Car Mechanics covered this about 2 months ago, all the different machines, would be worth paying £4 for a cold copy from them.
Old Mar 9, 2011 | 01:00 AM
dean3083's Avatar
dean3083
Me an friend just set up garage we got launch x431 master really good. Plus well rated by most garages. Say better than snap on. Plus if snap on gets confused it will say MAF sensor when not true.
Old Mar 9, 2011 | 07:19 AM
DAN P's Avatar
DAN P
most have problems with the maffs think you got to read between the lines with them
Old Mar 9, 2011 | 08:17 AM
john_p_b's Avatar
john_p_b
i've just got a snap on Ethos on demo for the week as our old heritage scanner is so out of date now i can't plug into anything post 2005! for the price the Ethos seems a decent machine but i'm still digging around to see if there is anything else up to a grand that can better it.
Old Mar 9, 2011 | 01:01 PM
DazC's Avatar
DazC
Depends if you want a code reader or a diagnostic tool...
IMO you can't go wrong with either a Bosch KTS340 or KTS670. They're both the same unit but the 670 has an oscilloscope. The other units worth considering is a Delphi unit. It's not just the ability to read codes but the information these machines carry, which is second to none.
I've played with several machines ad these are the ones that stand out the most, unless you're talking dealer spec tools or truck tools (which Texa is pretty good).
Old Mar 9, 2011 | 03:38 PM
krypton's Avatar
krypton
Wurth wow is a good one also.
Old Mar 9, 2011 | 04:09 PM
mk3cosproject's Avatar
mk3cosproject
ford crazie
Default diagnostic machines
in the garage i work juring the summer we got delphi, snapon and bosch. got training on the solus snap on which are quite cheap atm nd there fierce good havent tryed the bosch equilivant. if u dont mind not having the scope. if you want to go further up market both the snap on verus and bosch kts670 are on par with each other. tryed a Carman diagnostic in college was impressed too so have a look that way.
Old Mar 9, 2011 | 04:42 PM
gingeRS's Avatar
gingeRS
you just need knowledge of a decent calibration tool, a CAN USB converter and a laptop
well thats what i use
as for garage based units i wouldnt know
Old Mar 9, 2011 | 11:10 PM
ASHCOSSIE's Avatar
ASHCOSSIE
we use autologic , vagcom
Old Mar 11, 2011 | 01:57 PM
DazC's Avatar
DazC
From my experience, the Verus doesn't compare to Bosch to be honest. There is more detailed information on the Bosch unit, and a faster scope and the Verus is about 7.5k compared to the Bosch at 5.5k. The integration of the information system and the diagnostic system is extremely handy.
My advice is buy one high level tool to use as your main diagnostic tool and go on the courses that they offer you if you can. Then buy a second tool from a different manufacturer. This gives you coverage when your main tool won't connect to something (no manufacturer can make 1 tool that connects to everything), or if you have more than 1 vehicle in at once with problems.
Nov 1, 2015 06:53 PM
IainRS1700T
Sep 25, 2015 06:44 AM
