mondeo wont start
Old Mar 7, 2011 | 07:52 PM
actionfighter's Avatar
actionfighter
Default mondeo wont start
just had my injectors reconditioned and had mechanic drain fuel tank put on new filter and guess what it wont start he primed the filter and everything
anyone any ideas??
Old Mar 7, 2011 | 07:56 PM
rsturbolee's Avatar
rsturbolee
did they supply new codes with the injectors?? if so you will need to reprogram the car to them
oh and make sure he changes filter and blows out the fuel lines
Old Mar 7, 2011 | 08:03 PM
actionfighter
well Lee,ya got new codes with them but they said it should start and run 80 or 90% and then code them to get it spot on
Old Mar 7, 2011 | 08:27 PM
rsturbolee's Avatar
rsturbolee
yea it whould kinda run but id code them bleed up filter and pipes etc and keep trying, but if hes a decent mechanic he will know there a coont to bleed, i fill the filters with diesel with a syringe
Old Mar 7, 2011 | 08:34 PM
rsturbolee's Avatar
rsturbolee
oh and what the pressure at the rail at cranking etc, he must have a code reader etc surely?
Old Mar 7, 2011 | 08:36 PM
DanW@FastFord's Avatar
DanW@FastFord
Spelling Club King!
You won't need to code the injectors to run the car - it will start, jut run badly.
Priming the filter always seems to cause aggro. Some people crack the pipes off at each injector and turn it over until fuel comes out. I'm not a big fan, as there are some very high pressures to be messing with, and turning the starter over can overheat the pump and damage it.
It'll be an airlock somewhere!
Old Mar 7, 2011 | 08:38 PM
actionfighter
not sure exactly what he has done so far but ill buz him in the morning and see if he primed the filter,so you think they are hard to bleed?
im not sure if he coded them yet can they be coded with the ignition on but not running
Old Mar 7, 2011 | 08:40 PM
DanW@FastFord
Spelling Club King!
If he hasn't primed the filter he'll have no chance!
Old Mar 7, 2011 | 08:52 PM
actionfighter
ill report back to ye tomorrow evening,i suppose another day aint so bad,given the fact its been off the road over a month now!!
Old Mar 7, 2011 | 09:27 PM
mercury grey minter's Avatar
mercury grey minter
I always fill the fuel filter before fitting.If not i would try tow starting it.
Old Mar 7, 2011 | 09:35 PM
jameswrx's Avatar
jameswrx
Vacuum pump on the filter housing outlet, fills the filter nicely and draws fuel through feed (which gets air when filter comes off). This works every time for me now.
Just filling the filter never used to work as the air you'll get in the fuel line will cock things up as soon as it tries to start and stops the draw.
I've not had a faliure to start this way.
Old Mar 8, 2011 | 11:31 AM
scratch18's Avatar
scratch18
i normally fill the new filter to the brim fit it and start the car giving it high revs for about 30 secs, the high presure should bleed the air through. iwould of done this first to get it sorted really then done the injectors, if you have air lock its a bitch to get out
Old Mar 8, 2011 | 08:56 PM
actionfighter
All is good!!
Finally back on the road after nearly a grand and a month parked,he eventually got it on a tow also he spotted a cracked return pipe on the filter which he changed,It felt so good barrelling up the road home,it was only a short spin but it felt a bit more responsive and powerful although the mpg's were down to 31.5 but were slowly climbing,tomorrow will tell more,thanks to everyone for your help much appreciated!!
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
xrmalin
Sep 13, 2015 06:52 PM
Alun Gregory
Sep 6, 2015 09:40 AM
andrewmctiernan
Wheels and Tyres
Sep 3, 2015 08:22 PM
kevin36
Sep 2, 2015 06:24 PM
