76mm Air filters
WHY can I not find many anywhere !
I have seen the Grp A K&N that Rainbum sells but it won't fit in my engine bay.
The kit Matt Lewis sells also doesn't fit which is a PITA so it looks like I need a narrow filter. I'm trying to find one of the large cylindrical type ones as I know that will fit but can't see to find a supplier for them.
My other thought as air flow is not great on my car is to run a filter direct to the turbo rather than use a 90 degree hose which puts it in front of the cam pulleys, the reason for this is there is a hole in the inner wing where I suspect back at some point there was a cold air feed directly to the turbo assuming they just bolted a filter straight to the T4.
Thoughts and suggestions please, just spend a fair bit on a Matt Lewis kit and a reducing hose for it but none of it is any use to me now
Its looking that way mate, will drop you a PM later as I also ordered a hose for it only to find out the bloody filter wont fit in on top of the rad as it hits the bonnet
Looked on there, nothing like what I need though and I refuse to use anything thats dirt cheap.
Ive been thinking about something like this for my T4..
Comes with a 76mm reducer so can sit right in front of it.
SSooooo cheap though! Cant be any good surely?
http://www.apmotorstore.co.uk/mushro...ir-filter.html
http://www.merlinmotorsport.co.uk/im...l/jc60spec.pdf
i use itg too.
if you talk to them direct they will make whatever you want and are nice and cheap to.
i use itg too.
Johnny Knoxville
Sep 30, 2015 07:21 AM
