Spark plug recommendations please.
Old Mar 7, 2011 | 06:24 PM
sierrsteve1980's Avatar
sierrsteve1980
Default Spark plug recommendations please.
What plugs do you use? Also what would be a good spark plug for a car aroung 330bhp?
Any help would be great many thanks steve.
Old Mar 7, 2011 | 06:57 PM
siscossie's Avatar
siscossie
3-door moonstone
Im running NGK BKR8EIX irriduim plugs running 355bhp, there fine. Used to use champion c59c but had too many problems with them.
Old Mar 7, 2011 | 07:04 PM
botters's Avatar
botters
competant bodger
nothing wrong with standard ford plugs mate and at 7 quid a set cant be grumbled at
Old Mar 7, 2011 | 08:22 PM
kosienutter's Avatar
kosienutter
Last Time, Get Off PF FFS
second that.the standard ones are good enough and as said for the price well worth it.
Old Mar 7, 2011 | 08:26 PM
martysmartie's Avatar
martysmartie
Motorcraft 071's (Standard) for me and can vouch they are ok with the power you have.
Martin
Old Mar 7, 2011 | 10:09 PM
sierrsteve1980
Cheers guys i have set of the stabdard ones so i shall give them a try.
Again thanks for the help.
Old Mar 8, 2011 | 07:32 AM
MalZon's Avatar
MalZon
Bosch F2CS
Mvh Jonas
Old Mar 8, 2011 | 07:49 AM
ShiftyOldScoob's Avatar
ShiftyOldScoob
When I bought my saff it was running 071's and it was sound
Now running denso irridiums and there is no noticable difference so I'd go for the 7 quid jobbies
Old Mar 8, 2011 | 09:02 AM
DaveCrack's Avatar
DaveCrack
Found the 071's wear out faster / needed changing more often then the denso's.
Old Mar 8, 2011 | 10:51 AM
I have a set of ngk iridium plugs in mine there been in nearly 5 years. I was thinkin about getting a set of the ford plugs cause there cheap and a lot of people rate them.
Old Mar 8, 2011 | 06:52 PM
Nowt wrong with the 071, they are a tough plug, but IF mapped and running perfectly fuelling wise you will get better running with iridiums, I noticed a big difference when switching to a group a coil and iridiums, much crisper feeling engine, more eagerness low down, smoother idle, smoother elsewhere as well.
Old Mar 8, 2011 | 07:33 PM
wulliesxr4i's Avatar
wulliesxr4i
GIT-R-DONE
iridium plugs in mine runnin bout 300hp with grp a coil and its great,
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
phil51
Ford Focus Diesel
Oct 2, 2015 01:00 PM
deathrider666
Sep 28, 2015 06:12 PM
