parts clearout need this gone mtx75 etc
complete frs gearbox conversion for s2
shafts
frs box with atb diff
mounts
selector cables
focus rs clutch
focus rs flywheel
arp flywheel bolts
hydraulic clutch conversion
electronic speedo
the whole lot £1000
scorpion 2.5 exhaust system been modified to accept modified down pipe as above £100
16" team dynamics pro race 1.2 in black with red lip and toyo t1-r tyres wheels in good condition few minor marks not really noticable one tyre is low on the inside £250
stainless brake fluid res only for cars with no abs £40
fusebox cover £15
hks ssqv style dump valve with fittings £40
spec r header £65
bosch 044 £90
rs 4 spoke steering wheel with boss for s2 £150
bronze tint opening rear windows £60 (no rubbers)
freshly repainted rolling 90 spec s2 shell with interior koni suspension and cossie disk brakes all round complete minus parts listed above (please bear in mind this wasa modified car so viewing is a must as was running mtx75 etc) have v5 and some history £offers
will add more as i think of it please Pm if you require any more info or wish to make a purchase
Nothing is sold untill marked as sold and payment recieved due to previous time wasters
shafts
mounts
selector cables
focus rs clutch
focus rs flywheel
arp flywheel bolts
electronic speedo
the whole lot £1000
fusebox cover £15
spec r header £65
bosch 044 £90
if you have pic's can you post them anyway, i had the obx manifold and strugled to get the downpipe past the water pump with a t34, just want to see how you'v done it, might have another go with one...
I know the manifold sold mate but i'm considering buying one of them. Did it take up much more room, if any than the standard manifold and turbo setup?
I'd be fitting it in a mk2 fiesta so space is tight!
Grant
Grant
shafts
mounts
selector cables
focus rs clutch
focus rs flywheel
arp flywheel bolts
electronic speedo
the whole lot £1000
fusebox cover £15
spec r header £65
bosch 044 £90
shafts
mounts
selector cables
focus rs clutch
focus rs flywheel
arp flywheel bolts
electronic speedo
the whole lot £1000
fusebox cover £15
spec r header £65
bosch 044 £90
