Drag tyres which one's to go for
Old Mar 7, 2011 | 01:27 PM
QplateRST!'s Avatar
QplateRST!
1/4 mile beasty!!!!
Default Drag tyres which one's to go for
I'm after buying a set of drag slicks for my fiesta just after info on what ones are best and what sort of money they are!
Cheers Dean
Old Mar 7, 2011 | 01:32 PM
Luca's Avatar
Luca
Lukesville
You need a set that will fit under your arches or you will have the same issue I had.
What size wheels/tyre can you fit under the arch without it rubbing?
Old Mar 7, 2011 | 01:58 PM
QplateRST!'s Avatar
QplateRST!
1/4 mile beasty!!!!
205 50 15's are the max mate
Old Mar 7, 2011 | 02:24 PM
Luca's Avatar
Luca
Lukesville
Really think you will struggle mate without any mods.
With the drag slick they are really tall like fitting a (205 80 15) and in 15” you won’t get them under your arches.
Its either cut your wings out ( as in a good 3-4” around) or fit 13/14” wheels with drag slicks.
If you see below, 1st pic is 205/50/15 with standard arches
This pic is with the same 205/50/15 tyre but with the arches modified to take the drag wheels.
Then this pic is with the 26 x 8.0 x 15 drag slick. They are Massive!
Old Mar 7, 2011 | 02:42 PM
XRT_si's Avatar
XRT_si
I've got BFG Goodrich drag radials in around 205/60/15 I think. Never tried one on the Fiesta but certainly wouldn't have gone on without work.
Old Mar 7, 2011 | 03:12 PM
QplateRST!'s Avatar
QplateRST!
1/4 mile beasty!!!!
Think I'm abit stuck then can't get 14's over my brakes might have to get a brake kit sorted for the old girl!
Old Mar 7, 2011 | 03:23 PM
XRT_si's Avatar
XRT_si
What brakes are you on mate? Can't be bothered to find a copy of the mag lol
Old Mar 7, 2011 | 03:28 PM
Neil@FastFord's Avatar
Neil@FastFord
This its cossie stuff on Deans
Old Mar 7, 2011 | 03:31 PM
COCHYN's Avatar
COCHYN
Not being funny Dean, but since you're the quickest FWD, you really should be telling other people what tyre to use
Old Mar 7, 2011 | 03:37 PM
XRT_si's Avatar
XRT_si
If you has the same as my old set up of 4x4 Cossie callipers with Escort RS2000 discs then the right 14 inch wheels WILL fit
Old Mar 7, 2011 | 03:43 PM
Luca's Avatar
Luca
Lukesville
This is soooo true..... come on Dean whats the trick?
Old Mar 7, 2011 | 04:13 PM
QplateRST!'s Avatar
QplateRST!
1/4 mile beasty!!!!
ive only ever ran r888
Haha drive it like you hate it lol and i always try to snap the gear sick when changing gear!
As for my brakes there escort cosworth calipers and saph discs i rang compbrake the other day for a price on a brake setup Ł980 all in a little more than i wanted to spend tho
Old Mar 7, 2011 | 04:21 PM
XRT_si's Avatar
XRT_si
What size are those discs? RS2000 discs are direct fit and 260mm I think. and they go under 14s.
Old Mar 7, 2011 | 04:25 PM
QplateRST!'s Avatar
QplateRST!
1/4 mile beasty!!!!
I think there 280mm of the top of my head
Old Mar 7, 2011 | 06:20 PM
zippyobrien's Avatar
zippyobrien
260, I just put them Ali.g with 2000 calipers under my standard frst wheels
Mark RS
Mar 5, 2021 06:08 PM
tankybaby66
Feb 6, 2016 02:24 PM
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
Alloy wheels and ICE for sale
Sep 28, 2015 06:19 PM
