sierra sapphire abs fault
Hi having a problem with my abs light on my sapphire 4x4. comes on as normal and stays on. checked absolutely everything i can think of. Have continuity of around 1020 ohms on all sensors, and all wires from sensors to abs ecu are fine. also fluid level sensor is fine. green abs relay is ok and so is the fuse. only way i can get the light to go off is to take the lid off the green relay and bridge the contacts, so obviously power is not goin to the relay to activate it. anyone got any ideas? help would be really appreciated.
MAIN ELECTRO-VALVE TESTS
All tests performed with ABS ECU unplugged and ignition switched OFF unless stated otherwise.
-- Connect ohmmeter between ECU connector terminals 11 and 18. Resistance should be between 2 and 5 ohms.
o If the electro-valve resistance is OK, check for continuity between electro-valve connector (blue/white wire) and ECU connector terminal 18, and between electro-valve connector (brown wire) and earth.
CONTROL ELECTRO-VALVE TESTS
Resistance Test 1
-- Connect ohmmeter between ECU connector terminals 1 and 11
-- Resistance should be lower than 1 ohm
-- If value is not correct, check for continuity between ECU connector terminal 11 and electro-valve connector terminal 7 (brown wire), and check that terminal 7 on the electro-valve (corresponding with the brown wire) is earthed.
Resistance Test 2
-- Connect ohmmeter between ECU connector terminals :
-- If not, remove connector from electro-valve, and check resistance between the following electro-valve terminals (the brown wire is terminal 7):
-- If the values are correct, check for continuity between control electro-valve connector and ECU connector.
- If resistance is not correct, remove 2-way connector from main electro-valve and check that the resistance across the two terminals is between 2 and 5 ohms.
Resistance Test 1
Resistance Test 2
- 11 and 15
- 11 and 17
- 11 and 35
- 11 and 33
- 11 and 16
- 11 and 34
- 1 & 7 (LH front inlet valve)
- 2 & 7 (LH front outlet valve)
- 3 & 7 (rear inlet valve)
- 4 & 7 (rear outlet valve)
- 5 & 7 (RH front outlet valve)
- 6 & 7 (RH front inlet valve)
- ABS ECU connector terminal 15 & electro-valve terminal 1
- ABS ECU connector terminal 34 & electro-valve terminal 2
- ABS ECU connector terminal 17 & electro-valve terminal 3
- ABS ECU connector terminal 33 & electro-valve terminal 4
- ABS ECU connector terminal 16 & electro-valve terminal 5
- ABS ECU connector terminal 35 & electro-valve terminal 6
just to let you know got my abs fixed. turned out to be the abs ecu. checked a couple of second hand ones and turns out its a fairly common problem for them to go faulty. Thanks for the help.
Tony W
Sep 9, 2015 12:08 PM
Adam Graham
Sep 6, 2015 06:04 AM
