diagnosing brake pedal going to floor
Old Mar 6, 2011 | 07:55 AM
ballin's Avatar
ballin
Default diagnosing brake pedal going to floor
I'm fairly certain it's the master cylinder gone, but just wanted to double check the symptoms are correct? if I put my foot hard on the breaks there is a little resistance but not for long, but keeping foot hard down it doesn't quite reach the floor. if I pit my foot very lightly on the pedal, it sinks right down to the floor.
am I right in thinking this is master cylinder? I've bled brakes, no air in system, no leaks, fluid new and full.
the only other thing I could imagine is servo but not sure what tests I can do to rule one out/confirm the other?
no abs involved, it's a 98 punto 1.1
Old Mar 6, 2011 | 08:55 AM
left hooker's Avatar
left hooker
has this happend before or after bleading your brakes?
Old Mar 6, 2011 | 09:01 AM
Oranoco's Avatar
Oranoco
If the servo had packed up the pedal would be very heavy.
Old Mar 6, 2011 | 09:02 AM
ballin's Avatar
ballin
before bleeding.
Old Mar 6, 2011 | 09:24 AM
Cozziekid's Avatar
Cozziekid
Did you do any work on the braking system before this happened? Sounds like master cylinder to me. I never push brake pedal all the way to the floor when bleeding brakes, only about half way, some cars dont like it and it damages the seals.
Old Mar 6, 2011 | 09:47 AM
dojj's Avatar
dojj
Resident Wrestling Legend
Master cylinder would be first on the list as you'd get a very hard pedal with no servo
Old Mar 6, 2011 | 10:27 AM
Spiky's Avatar
Spiky
had this on my pedal box, was MC
Old Mar 6, 2011 | 10:33 AM
RickyLee53's Avatar
RickyLee53
Only usually when the master cylinder is damaged/worn. IMO it needs changing then anyway.
Old Mar 6, 2011 | 11:08 AM
st3v3's Avatar
st3v3
Master cylinder is fooked, they have two, maybe 3 sets of seals on them just incase the first let go,you then have the 2nd set to catch the fluid, i think this is why you are feeling resistance, then fades away.
If you have no visable leaks then id def change the master cylinder.
Old Mar 6, 2011 | 11:16 AM
studabear's Avatar
studabear
to be double sure clamp all 4 brake hoses and see if the pedal goes normal, if it does take 1 clamp off at a time checking pedal after each, if pedal becomes crap again then the problem lies on the corner you unclamped last
If the pedal is still crap with all hoses clamped off then its the master cylinder
Old Mar 6, 2011 | 01:34 PM
ballin's Avatar
ballin
nice one, cheers all!
muzzman1
Sep 30, 2015 08:59 PM
Sp3no
Sep 27, 2015 07:23 PM
