group a coil part no. and wiring
is this the part no. for a marelli group a coil,
60705606010
BAE506F
i think it is one but i just wantto make sure befor i fit it
also i have reard about people using a relay to wire them up, i take it you take 12v striaght from the battery and use the original wire as a trigger for the relay
thanks nick
60705606010
BAE506F
thanks nick
Don't know about the part number, just buy from matt lewis on pf and you will be getting the genuine thing.
You can use a relay to wire up as you describe, but imo not necessary.
Use the new coil with some iridium plugs for best effect.
