03 fiesta 1.4, anyone done a cat???
Hi all!
I'm having trouble with the wifes fiesta, basically garage says its the cat gone. They have said its a big job because cat is behind engine. Anyone swooped one?
Cheers all!!!
Cheers all!!!
Yeh the drive shaft has a bearing carrier that bolts to the back of the block. Undo the 2 13mm nuts take the bracket off then remove the shaft right out. You will have to remove the top exhaust heat shield. Hopefuly the bolts wont round off. If i was you i would get a proper ford one cause the garage i worked at,at the time i fitted 2 mickey mouse cats and the car kept coming back. I fitted a proper ford one and never seen the car agan.
sridgett
Oct 1, 2015 07:30 PM
Steve Escos
Oct 1, 2015 06:57 AM
Orion_Gav
Sep 29, 2015 04:50 PM
deathrider666
Sep 28, 2015 06:12 PM
