L6 ecu to L8
Old Mar 2, 2011 | 11:50 PM
dazzle740's Avatar
dazzle740
Default L6 ecu to L8
Hi there all
Basically folks I have changed the standard L6 ecu on my 2wd saph to a L8 ecu as many of you cossie owners have done before, but what I was wondering was, is the 'guts' of a L8 transferable to a L6 case and if any of you have done this already from experiance how difficult of a job is it.
Old Mar 3, 2011 | 10:55 AM
jon@work's Avatar
jon@work
Yes they are.
Old Mar 3, 2011 | 06:33 PM
cozzy jeff's Avatar
cozzy jeff
whats the reason for doing this though?
Old Mar 3, 2011 | 08:14 PM
jon@work's Avatar
jon@work
easier mounting, in my case
Old Mar 3, 2011 | 10:40 PM
cossiedad's Avatar
cossiedad
Does this mean you will have the 'guts' of a working L6 spare? If you are looking to sell it please pm me a price? Some muppet has glued my chip in to the board!
cheeRS
Old Mar 4, 2011 | 12:42 AM
dazzle740's Avatar
dazzle740
The main reason for doing this is so the ecu would still bolt securely into place as standard as at the mo it is wedged in with a bit of rubber to stop it moving about.
Cossiedad no sorry mate the L6 was faulty thats why when looking for a replacement was recommended to change a L8 instead.
Jon@work does this mean you have done this? if so is it difficult is it simply unsrew it and screw into old case or more fiddly than that?
Old Mar 4, 2011 | 03:05 PM
jon@work's Avatar
jon@work
It's just a few screws and IIRC 7 spring clips to undo, but you've also got to drill and tap the mounting holes in the L6 case for the baby board.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
griffo69
Oct 4, 2015 11:58 AM
R4N SS
Ford XR Parts For Sale
Sep 15, 2015 03:38 PM
DixieTheKid
Sep 14, 2015 09:04 PM
Tank Mike
Sep 14, 2015 03:56 PM
