Final Clearout - Updated
Old Feb 27, 2011 | 10:04 PM
Kelv's Avatar
Kelv
Almost there!
Default Final Clearout - Updated
Smaller items im happy to post.
some of the larger/bulkier items which may be grubby, i would preffer collection or a more local meet.
Cheers.
Escos gearnob, perfect condition other than the tiniest mark on the lower lip (shown in the pictures) - £10
2wd gearbox crossmember - £5
4wd gearbox crossmember - £10 Reserved
Escos Passenger side kick sill trim - £3 (quite scuffed in places)
Escos ARB - £10
Escos main propshaft, not long had new centre bearing fitted - £20
Exhaust under-car heatshield - £15
Escos Front door card insets - £4
PAS mounting bracket - £10 Reserved
2wd airbox, corner section pre-trimmed for escos fitment - £20
Escos glovebox cover - £10 Reserved
MT75 Gearbox - £40 (this is what you would use if going rwd and wanted to fit a Quaife/bara/Fixit gearkit, bought as a spare from Reyland) Reserved
4X4 Front diff - £25
GGR exhaust, decatted and downpipe modded for 2wd manifold fitment - £100
2wd steering rack & pump - £20 Reserved
pair of standard stereo amps (Escos)
one has had some sticky tape applied for a hands free speaker, and the other was in my old black escos which was rolled, so a few scuffs to the mounting bracket.
£5 for each
plus a bit of the wiring - £2 maybe :dunno:
Old Feb 27, 2011 | 10:27 PM
a-mac's Avatar
a-mac
interested in the 4x4 steering rack does it come with all the pipes and hoses
how much for postage
thanks
Old Feb 27, 2011 | 10:48 PM
Kelv's Avatar
Kelv
Almost there!
it will be unbolted from the crossmember and can come complete with everything else thats attached and within the picture mate.
as for postage, i wouldnt like to say on that, i dont think the post office will be keen on an item that could leak oil.
where is Hamilton, could you collect?
Old Feb 28, 2011 | 03:39 PM
peteh's Avatar
peteh
what's the 2wd rack like? have you had it on a car at all, mines leaking bad that's all.
Old Feb 28, 2011 | 05:55 PM
a-mac's Avatar
a-mac
sorry could not collect , hamilton is just out side glasgow
could you not try and drain most off the oil out and put in plastic bag in
then put in a box
thanks andy
Old Feb 28, 2011 | 06:05 PM
Kelv's Avatar
Kelv
Almost there!
bare with me Andy, ill see what i can do tomorrow
Peteh, ive not tested or used it, i bought it off a guy on here who had it on a fully working car that he then broke.
Old Feb 28, 2011 | 06:20 PM
1300gt's Avatar
1300gt
Is the throttle cable for eeciv or older YBG etc
Old Feb 28, 2011 | 07:24 PM
Kelv's Avatar
Kelv
Almost there!
Sorry Mark, its just sold.
Old Mar 1, 2011 | 06:54 PM
1300gt's Avatar
1300gt
Default /
Bugger ! free bump
Old Mar 1, 2011 | 10:30 PM
Kelv's Avatar
Kelv
Almost there!
Cheers Buddy
Old Mar 2, 2011 | 08:09 PM
R4N SS's Avatar
R4N SS
Is that a front or rear arb?
Are the escos arbs thicker than 3dr ones and are they an improvement?
If so I will have it and can collect on the weekend
Old Mar 2, 2011 | 09:01 PM
Warren's Avatar
Warren
Kelv, I'll take the glove box lid please
Old Mar 2, 2011 | 09:15 PM
Kelv's Avatar
Kelv
Almost there!
No problem Waren
Ran, its a front ARB mate, i cant answer if they are thicker than a 3dr item tho, i can measure it up against the 2wd saph item i have tho (i can only assume a 2wd saph and a 3dr ARB are the same? )
Old Mar 3, 2011 | 12:45 PM
R4N SS's Avatar
R4N SS
no worries - i have a front arb already and wanted a rear.
cheers
Old Mar 3, 2011 | 08:37 PM
rich123's Avatar
rich123
Cheers.
2wd gearbox crossmember - £10
BT Escos fuel rail - £30 (good condition, just dusty/grubby)
Escos cone filter heat shield - £10 (will clean up spotlessly, just been sat in the garage for some time) Reserved
Brand new Escos throttle cable - £15 Sold
Escos Passenger side kick sill trim - £5 (quite scuffed in places)
Escos ARB - £15
GT30/35 exhaust mount converter (Reyland) - £60 Reserved
Escos main propshaft - £35 (had a brand new centre bearing fitted just before the car came off the road for its build up)
Escos rear driveshafts - £25 ea / £40 pair.
2wd manifold - £40 Reserved
Exhaust under-car heatshield - £30
4x4 Gear selector shaft - £10
Escos Front door card insets - £10 Reserved
Smoked front bumper indicators - £10 Prov Held
Escos Spare wheel carpet cover - £10
Cossie yellow injectors - £20 (not sure what cossie they are from, been bagged in the garage for some time)
2wd airbox, corner section pre-trimmed for escos fitment - £30
Brand new front top mount bearings - £10 Sold
Brand new stereo blanking panel - £10 Reserved
Banana pod gauge, mounting bracket - £5 Reserved
MT75 Gearbox - £80 (this is what you would use if going rwd and wanted to fit a Quaife/bara/Fixit gearkit, bought as a spare from Reyland)
4X4 Front diff - £60
Pair of stub end front shafts - £25 Reserved
Escos steering rack, included the link arm/knuckle up to the steering column - £35 (crossmember already sold)
2wd crossmember/ARB & TCA's - £30
GGR exhaust, decatted and downpipe modded for 2wd manifold fitment - £125
2wd steering rack & pump - £30
Brand new radiator fan switch - £10
brand new plenum cover gasket - £5
delete aero lower spoiler with carbon wolf - £300
Engine metal water pipe - £15 (runs down the side of the engine past the turbo)
wing/door vinyl trims - £15 (these fit to the back of the front wings, the section that is visible when the door is open) Sold
i also have a pair of standard front seat subframes for sale - £30 Reserved
and i have a T3 turbo for sale, came off a mates saph but now mine in a deal of parts. Overal good condition but just a bit grubby externally - £100
and with someone pulling out on me on here (no contact for 3 weeks after they claimed they transfered the money and now now not answering there phone (JDCRST)) i will now have 4 stack 52mm gauges for sale which have never been wired up, will be in there boxes as new.
gauges are:
Oil pressure - £110
Oil Temperature - £70
Water Temperature - £70
Exhaust Gas Temperature - £85
if someone wanted all 4 as a job lot, ill do them for £300 collected/£310 delivered
hi not being funny like but cant you get these stack gauges for aroubd 50 quid from demon tweaks
Old Mar 3, 2011 | 09:57 PM
Kelv's Avatar
Kelv
Almost there!
you copied my whole thread just to say that
and no you cant mate, the prices ive put these up for are aprox £25 less (each gauge) than they are brand new
Old Mar 4, 2011 | 08:25 PM
jonesymk2's Avatar
jonesymk2
Im interested in the prop please mate,billu djd try to call you earlier but thinks youve changed your number,i could probably pick it up one evening in thevweek if thqts ok,any chance of metting you at some services or anywhere to make it a bit easier as got to come from luton,could you let billy know or me either way whatever is easiest please billy does have my number
Old Mar 4, 2011 | 10:02 PM
Kelv's Avatar
Kelv
Almost there!
Ill PM you my number, its not changed tho buddy, and ive got no missed calls
Prop is yours if you want it , give me a shout when you get the PM and we can hatch a plan
Old Mar 5, 2011 | 07:55 AM
carl/saff's Avatar
carl/saff
SIERRA RS 4X4 COSWORTH
Pm sent kelv
Old Mar 5, 2011 | 08:08 AM
Kelv's Avatar
Kelv
Almost there!
Replied Carlito
Old Mar 6, 2011 | 08:01 AM
carl/saff's Avatar
carl/saff
Replied mate
Old Mar 7, 2011 | 12:59 PM
Kelv's Avatar
Kelv
Almost there!
Updated.
Old Mar 25, 2011 | 10:20 PM
Kelv's Avatar
Kelv
Almost there!
UP AGAIN.
further price drop's to try and shift the bits on
Old Mar 26, 2011 | 06:34 AM
t3 dan's Avatar
t3 dan
you have pm
Old Mar 26, 2011 | 12:04 PM
Kelv's Avatar
Kelv
Almost there!
replied mate.
Old Mar 26, 2011 | 07:50 PM
john_p_b's Avatar
john_p_b
Whats the model number of the stack water temp gauge? Is it complete with wiring etc?
Old Mar 27, 2011 | 09:58 PM
Kelv's Avatar
Kelv
Almost there!
yes, it will come in the origonal box with all wiring instructions, wiring loom, sensor, clips, grommits etc as the day it left the factory.
only the gauge itself had been removed from the box to be fitted into a panel for a mini feature with FF.
model number i believe (by the sticker on the side) is: ST3307
or this one: http://www.demon-tweeks.co.uk/Motors.../1771/151/1751
Old Mar 27, 2011 | 10:25 PM
7sean7m7's Avatar
7sean7m7
Would you sell the back box seperate?
Old Mar 27, 2011 | 11:03 PM
Kelv's Avatar
Kelv
Almost there!
If you turn up with £100 mate, you can take the whole system
Old Mar 27, 2011 | 11:16 PM
7sean7m7's Avatar
7sean7m7
Only need the bax box though mate :/ Would you sell it seperate?
Old Mar 28, 2011 | 10:18 AM
Kelv's Avatar
Kelv
Almost there!
Ideally not as I can see it being a pain to sell on the rest of the system on it's own.
BUT, if the back box went for £80 then I'd be happy to separate it all
Old Mar 28, 2011 | 06:35 PM
scholesyy's Avatar
scholesyy
Any idea on the condition / millage of the mt75?
Old Mar 28, 2011 | 07:53 PM
Kelv's Avatar
Kelv
Almost there!
i cant help you on mileage, it was believed to be a fully functional and working box tho.
i purely bought it to use for a straight cut kit to RWD the escort, but never got round to doing so, and for that reason i never enquired about mileage
Old Mar 28, 2011 | 08:30 PM
johnenright150rst's Avatar
johnenright150rst
sorry to hijack ur forsale thread mate, but by any chance to you now have a m1 frs?
Old Mar 28, 2011 | 09:29 PM
Kelv's Avatar
Kelv
Almost there!
i do yes mate.
why is that buddy?
Old Mar 28, 2011 | 09:37 PM
johnenright150rst
Reason i asked is i think my brother polybushed most of the car?
If im right its a lovely looking car love all the carbon
I poped round to get his advice on an issue i had with my s2 and saw the car then.
Take it he showed you his s1
Old Mar 28, 2011 | 09:52 PM
Kelv's Avatar
Kelv
Almost there!
i assume we are reffering to Andy, with the RWD Cossie S1
if so, yep it was your brother.
quite liked your dads motor aswell, and im not reffering to the Evo
Old Mar 28, 2011 | 09:59 PM
johnenright150rst
Yep thats him
Did the bushes make much diffrence?
I love his s1 cos power with s1 looks perfect imo
I love my old mans hotrod aswell, i was out in it practicing the other week revs to 8800 rpm its a wepon.
Old Mar 31, 2011 | 03:55 PM
Kelv's Avatar
Kelv
Almost there!
ive not really used the car a great deal to say yes or no to them making a difference.
especially when it was combined with alot of other work over a week or so, im sure its helped tho
main post edited to shift things on quicker and cheaper
Old Apr 2, 2011 | 08:39 AM
t3 dan's Avatar
t3 dan
Parcel came yesterday many thanks mate
Free bump
mondeomark
Sep 28, 2015 06:28 AM
